Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > RC4WD Bully
Thread: Name of semi-circle non-rotational Wheel Weights?
Old 03-13-2022, 07:51 PM   #1
Default Name of semi-circle non-rotational Wheel Weights?
A while back I saw a semi-circle that always faced downwards from the axel, providing weight down low below the axel. What is this type of weight called and where can we buy some?
Rockiteer is offline   Reply With Quote
Old 03-13-2022, 08:28 PM   #2
Default Re: Name of semi-circle non-rotational Wheel Weights?
Dlux Fab has their Loaded Dice weights that works with their Loaded Dice wheels and Dlux knuckles https://dluxfab.ecwid.com/Loaded-dice-weights-p88475262
HumboldtEF is offline   Reply With Quote
Old 03-27-2022, 10:55 AM   #3
Why do you need special wheels and foams to work with loaded dice hangers? Don't they sit within the wheel? Not sure why new foams are required for those.
Krawler23 is offline   Reply With Quote
Old 03-27-2022, 12:08 PM   #4
I've never use them but just from the pictures its clearly much larger hence the special requirements
Heres my Bully 2 with stock (2.2") wheels. You can see these just barely clear the normal Dlux Knuckles
Then compare to this picture, notice how much more space these take up compared to just the Dlux knuckle itself, these occupy the space past the bead of the tire.
https://d2j6dbq0eux0bg.cloudfront.ne.../535840220.jpg
The loaded dice weights end up in the space your stock wheel inner ring/barrel is
Theres no mention of foams that I see.
Old 03-29-2022, 04:07 PM   #5
on the rc4wd site they are called bully 2 knuckle weights. they show 2 on each side creating a full circle, might be able to just mount the lower since each half mounts seperately.
wander is offline   Reply With Quote
Name of semi-circle non-rotational Wheel Weights? - Similar Threads
RC4WD Semi Wheel question ScaleLifeNewbie Tires and Wheels 3 01-02-2022 12:48 PM
Knuckle Weights vs. Wheel Weights Harvo Tires and Wheels 34 11-16-2011 01:15 PM
Rotational slop BigRocks Axial AX-10 Scorpion 3 01-20-2008 10:12 AM
semi wheel chip cross 1.9 Scale Rigs 2 03-13-2007 07:34 AM
