Thread: Shifting question
Old 04-15-2012, 12:50 PM   #1
Default Shifting question
Are you guys using an R/C aircraft retract servo to shift gears? My TF2 is on the way so I would like to know. Thanks for the help.
raceeng18 is offline   Reply With Quote
Old 04-15-2012, 01:57 PM   #2
Default Re: Shifting question
Some are using the Hitec Ultra Micro HS-55 and also i found this TF2 tips and tricks thread
jvella is offline   Reply With Quote
Old 04-15-2012, 04:24 PM   #3
Interesting stuff there, thanks for that. I just wonder if a retract servo would work?
Old 04-15-2012, 05:05 PM   #4
I don't see why a retract servo wouldn't work. Just as long as you can set the EPA on your radio so it doesn't go too far.
pardonmyn00b is offline   Reply With Quote
Old 04-16-2012, 10:09 AM   #5
I assume a standard servo will work as well?
Grumpster1980 is offline   Reply With Quote
Old 04-16-2012, 12:46 PM   #6
Yep
Shifting question - Similar Threads
shifting 4x4wheelier 1.9 Scale Rigs 2 11-25-2008 10:16 PM
shifting Q's miniguy General Scale Talk 1 04-27-2008 04:29 AM
TQ-3 Shifting switch Dreadd Newbie General 3 09-27-2007 02:35 AM
shifting problem!!!! redjeeper General Crawlers 9 06-05-2007 11:46 AM
Shifting Questions player General Crawlers 8 01-11-2006 03:42 AM
