06-20-2012, 05:50 PM | #41 |
Rock Crawler Join Date: Nov 2010 Location: the 'burgh'
| Re: replacements for tf2 driveshafts
The black steel punisher shafts are working great for me. Using the rig a couple times a week for three months now. no problems. I run MIP's in most rigs but these are a tad more scale and are really durable. |
06-21-2012, 04:12 AM | #42 |
Newbie Join Date: Jun 2012 Location: bangalore
hi all .. need a little help.. what size junfac driveshafts are u guys using for the front and back in tf2? im placing an order but dont know which size as some say scx10 fits, some say honcho .. do i need the 82-117mm ones or the 95-130mm ones ? |
06-21-2012, 04:55 AM | #43 |
Quarry Creeper Join Date: Mar 2012 Location: Brooklyn, New York
the 95-130mm are the ones I ordered and they fit.
06-21-2012, 06:02 AM | #44 |
Newbie Join Date: Apr 2012 Location: Seekonk
I put the 95-130 set in mine.
06-21-2012, 06:09 AM | #45 |
ohoki .. thank you all .. il be ordering 2 of the 95 ones front and back . |
06-22-2012, 10:05 AM | #46 |
Newbie Join Date: Jun 2008 Location: New Brighton
I have 2 TF2's and installed the drive shaft rings from Axial and HotRacing and have had no issues. The rings are a bit bigger then the drive shafts but they still do the job. If you can't find them I have made rings from brass tubing and drilled and tapped holes for set screws and they worked just the same for less money.
07-03-2012, 12:58 PM | #47 |
Quarry Creeper Join Date: Jun 2012 Location: Vancouver, WA
I ordered up a pair of JunFac shafts. Should be here Thursday. Any tips on installing them or they straight forward like the stock shafts?
03-23-2016, 09:57 PM | #48 |
Newbie Join Date: Feb 2016 Location: amanda ohio
My tf 2 came with rings, and I glued them and safety wired them an they still broke in ten minutes. Also came with rubber mirrors that only lasted a couple of runs. Only running 35t motor on nimh
03-23-2016, 11:32 PM | #49 |
Newbie Join Date: Mar 2016 Location: Hochatown Oklahoma
Ok , I need in this conversation if yall dont mind. I too own a trailfinder 2, and I would like to know .where do I look for Mips . And/or what length shafts would I buy, if I got the ultra scale shafts from Rc4wd or Mips.? I made sleaves for my stock shafts out of aluminum tubing .I know thats not the problem area, but hey, they look good. Lol Im waiting on a few more parts in the mail and I get to run mine finally. Maybe I'll get 30 minutes out of it before the shafts are gone. Sent from my GT-P3113 using Tapatalk |
03-24-2016, 01:18 AM | #50 |
I wanna be Dave Join Date: Apr 2014 Location: North Carolina
RC4WD has a compatibility chart for driveshafts on their site: http://rc4wd.com/Doc/Shafts.pdf Lots of choices there. Among the metal ones, the only ones to stay away from are the v3 steel punishers. |
10-03-2017, 04:44 AM | #51 |
Pebble Pounder Join Date: Jan 2017 Location: @scaleobsession on instagram
Has anyone an an issue with the holes on the junfacs not lining up with the holes in the pinion shaft/transfer case shaft?
10-03-2017, 06:07 AM | #52 |
| Re: replacements for tf2 driveshafts All of my RC4WD axles and t-cases have needed the output shafts shortened slightly when using shafts other than RC4WD ones. Grind just enough off the end to get the holes in the output shaft to line up with the holes in the driveshaft.
replacements for tf2 driveshafts - Similar Threads | ||||
axial replacements | redcatguy | Axial XR10 | 15 | 10-09-2010 02:36 PM |
Comp Crawler CV Replacements | Rich Trujillo | Team Losi Comp Crawler | 16 | 06-15-2009 05:16 PM |
o-ring replacements! | mudrinner4ever | General Crawlers | 8 | 06-12-2006 06:06 PM |
Rooster replacements? | wheeler | Electronics | 4 | 01-30-2005 01:35 PM |
