07-05-2012, 03:03 PM | #1 |
RCC Addict Join Date: Dec 2007 Location: London
| ***Overdrive Underdrive Project ***
Yes you read write Overdrive Underdrive Mod. Pictures its work in progress but a Quick Test has proved positive that it works so I will continue with this Build. Basically I have moved the Trans over to the other side (I need to make another mount for the other side. The Transfer Case has had the shaft flipped round inside. The Rear Prop angle is now better and the front comes down the correct side to the pumpkin. By doing this the Transfer Case is now higher and the Steering drag link is on the correct side. A quick Test Run gave a much better turning circle. The Single output on the Transfer Case spins round faster than the others. Whether it will affect gearing or not i'm not sure so I might need to look at the spur and pinion arrangement later on. More Soon. Last edited by Dready; 07-05-2012 at 03:07 PM. |
07-05-2012, 03:35 PM | #2 |
Rock Crawler Join Date: Apr 2005 Location: Monroe, Louisiana
| Re: ***Overdrive Underdrive Project *** Subscribed and waiting to see some video.
07-05-2012, 03:43 PM | #3 |
RCC Addict Join Date: Feb 2012 Location: Ca.
I've never used overdrive/underdrive before so I'm just asking. Won't they be working against one another?
07-05-2012, 04:03 PM | #4 | |
| Re: ***Overdrive Underdrive Project *** Quote:
Nope the Front Axle turns faster than the rear. So when you steer you get a better/tighter Turning circle. Axial make specific gears for this purpose. The Rc4wd Yota axles are limited to a single setting. Still Wrenching Video Soon as its runable. | |
07-05-2012, 05:33 PM | #5 |
RCC Addict Join Date: Jul 2008 Location: Fox Valley WI
The other advantages are that the front end tends to stay planted better during breakover climbs, rather than backflipping or wheelying. It also helps with steep descents, effectively like riding the rear brakes. Turning radius should be much improved. If this mod works out, we'll have to name it after you . |
07-06-2012, 09:17 AM | #6 |
Pebble Pounder Join Date: Oct 2008 Location: mid state
wondering if adding something like this would help with the propangle alog with this setup? Superlift Driveshaft Alignment Degree Shims |
07-06-2012, 12:00 PM | #7 | |
I already have some of them that I was going to add | |
07-06-2012, 12:24 PM | #8 |
More Pics been mucking around with this today. I got the motor sitting lower. The Drivers Side Engine mount is the passenger one flipped over and a couple of small spacers added. The Passenger Side is a Leaf Link bent 90 degrees and mounted to one of the holes on the engine mount. This pic shows that a small amount had to be filed out to clear the chassis rail. You can also see that I left out one of the silver barrel spacers it wouldn't quite clear the shock hoop The Electonics tray plate was raised off the rails and the transfer case mounted to it. I'm working the Shift Servo Out now so once that's done i'll shoot some video. Last edited by Dready; 07-06-2012 at 12:28 PM. |
07-06-2012, 12:40 PM | #9 |
Moderator Join Date: Jan 2004 Location: chicago
fantastic thinking here! |
07-06-2012, 01:44 PM | #10 |
Video Just uploading now |
07-06-2012, 01:44 PM | #11 |
RCC Addict Join Date: May 2010 Location: Midwest
| Re: ***Overdrive Underdrive Project *** |
07-06-2012, 01:49 PM | #12 |
| Re: ***Overdrive Underdrive Project *** RC4WD Trailfinder 2 Gearing Test - YouTube Video I think its made quite a diffence it will be interesting to see how it performs on the dirt. Which I haven't got here living in Central London!! |
07-06-2012, 05:04 PM | #13 |
Quarry Creeper Join Date: Jun 2012 Location: Vancouver, WA
Love it! I was just thinking that the TC should be setup differently to match real yota TCs. The jumping in the video while turning, is that the effect you were using for the video or does the rig jump when turning? |
07-06-2012, 11:08 PM | #14 |
| Re: ***Overdrive Underdrive Project *** I was getting a little glitch from the electrics because they were just thrown on.
07-07-2012, 05:53 AM | #15 |
Rock Crawler Join Date: Jan 2007 Location: UK
Nice work on re-arranging the driveline, that's not as straight forward as it seems. Given that the tcase is 1.47:1 is the difference in ratios too much? |
07-07-2012, 08:07 AM | #16 |
1.47:1 = the front being 0.47 x's faster? If so, it should work out. The difference between the combo of OD & UD in an AX-10 is 0.73.
07-07-2012, 09:03 AM | #17 |
07-07-2012, 09:59 AM | #18 |
So I continue. Leafs up front weren't cutting the Mustard so they've gone now. I had the proper Yota Axle 4 link mount but no centre mounts as I used them on the Blackwell Yota. So I used the Leaf Mounts that should go on the rear. They fit in the Original Holes which is a result!! 3 Links on the Front because it wouldn't clear the prop on the other side. Front Panhard running Parallel to the steering Drag link. Its everso slightly longer but I get almost zero Bump Steer. The Shift Servo is now mounted at the front as there's room next to the Transmission I also got some new wheels for it today thanks to 'redneck21' I have some New Props and some of those New Gmade Shocks on there way so I'll update this some more once those parts arrive. In the meantime I have the electronics to mount. More Soon |
07-07-2012, 07:03 PM | #19 |
ilike the drag link. wondering if i could attach a draglink with the front leafspringsin the same fashion.just using a longer bolt for theleaf spring and ball end
07-07-2012, 08:22 PM | #20 |
I wanna be Dave Join Date: May 2011 Location: Lost in Oregon
Interesting mod....seems to work good so far. After eyeing the first picture you posted...wondered how long the front leafs were going to last.... |
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/rc4wd-trail-finder-2/391716-%2A%2A%2Aoverdrive-underdrive-project-%2A%2A%2A.html | ||||
Scale RC - Page 415 - R/C Tech Forums | This thread | Pingback | 02-19-2013 09:54 PM |
***Overdrive Underdrive Project *** - Similar Threads | ||||
Overdrive or Underdrive | neillarson | Axial SCX-10 | 20 | 03-04-2014 12:11 PM |
Trex 60 axle overdrive/underdrive? | CrawlinMike | General Crawlers | 7 | 03-30-2012 05:36 PM |
No more underdrive or overdrive gears? | C_Money | General Crawlers | 21 | 07-07-2011 11:54 AM |
Overdrive and underdrive | dmcchaser | Newbie General | 4 | 06-18-2010 02:04 PM |
