03-17-2014, 08:31 AM | #21 |
Quarry Creeper Join Date: Dec 2009 Location: West Alabama
| Re: yet another TF2 thread.......
well there goes an impulse buy I have no explanation for....Also headed to town for some home improvement items, and probably a new color for the truck GMade SR02 beadlocks (uncoated) Baja MTZ 1.9" single silver Pro10 spare single Irok 1.7" spare spare tire bed mount new windshield 11T pinion |
03-17-2014, 11:45 AM | #22 |
RCC Addict Join Date: Oct 2012 Location: Charleston South Carolina
Suspension plans? Also, Where are you located in AL? |
03-17-2014, 12:34 PM | #23 |
nothing planned suspension-wise. running red leafs with shortest leaf underneath. stock shocks. I do have 4mm homemade lift blocks. i've got plenty of flex and just enough clearance for the Iroks I live in Fayette, work in Tuscaloosa. Its about a 45 min drive Last edited by nharkey85; 03-17-2014 at 12:37 PM. |
03-21-2014, 09:05 PM | #24 |
1.9 MTZs and gmade sr02s. had a decent side shot but it magically deleted itself within the last 10 minutes. thinking about painting the inner wheel piece black to define the cut-outs in the outer piece Last edited by nharkey85; 03-21-2014 at 09:08 PM. |
03-29-2014, 08:22 PM | #25 |
Color change in process........24hrs later color change done.... Also pro10s got a fresh coat of satin black Forgot to mention and forgot to get good pics, but sanded the side emblem locations smooth and smoothed the center line of the hood Sent from an SG3-Mini Last edited by nharkey85; 03-30-2014 at 07:21 PM. |
03-30-2014, 06:02 PM | #26 |
| Re: yet another TF2 thread....... |
04-06-2014, 07:16 PM | #27 |
Swapped in an old losi 1/18 brushed esc for servo winch contol purposes. Having finer control instead of on/off, plus variable speed is nice Also turned down the drag brake in the fxr Sent from an SG3-Mini |
04-10-2014, 04:16 PM | #28 |
Rock Crawler Join Date: Jul 2012 Location: Albuquerque, New Mexico
It's looking very good.
04-13-2014, 08:10 PM | #29 |
RCC Addict Join Date: Feb 2012 Location: Ca.
How's that electronics plate mounted t case working out for you? Mine sure does get hung up, I may copy your idea.
04-14-2014, 10:20 AM | #30 |
Works well. No binding in the driveshafts. Definitely clears obstacles better Sent from an SG3-Mini |
04-14-2014, 01:29 PM | #31 |
04-20-2014, 07:01 PM | #32 |
i've got gmade scale hubs on it now, and put in the rc4wd inner fenders. no pics tho found the pics of the smoothed sections of the body. side emblem hood and after a good couple runs Last edited by nharkey85; 04-20-2014 at 07:03 PM. |
06-02-2014, 07:04 PM | #33 |
few more mild changes, Im diggin the new look! RC4WD Pro10s wrapped with 1.7 Iroks, secured with LURC acorn nuts and Gmade scale hubs Last edited by nharkey85; 06-02-2014 at 07:21 PM. |
09-11-2014, 07:15 AM | #34 |
been doing some mild switching and swapping, will edit post with some updated pics in a bit. in the market for slightly shorter tire, currently running 4.18-4.19 (iroks-mtzs). looking into some right around 4", gives a happy medium from stock 3.74s and what i have now |
09-15-2014, 08:27 PM | #35 |
So ive got some new rubber mounted up and i think ima like em. 1.9 dirt grabbers on gmade metal beadlocks (raw and rusty) Also since i had to pull my CC-BEC out to be sent in, i pulled everything out and did some relocating. Ordered new power hd 1501 servo for steering duties and a gforce 2600mah 3s lipo (valuehobby) So we're looking at tekin fxr mounted on the forward face of the power hd servo, my sr3100 rx on top of the servo, an older airtronics servo for shifting. Its mounted in the stock location even though i have raised and moved the plate forward. The lipo will be strapped down on the plate in the intended stock location, resting on a 1/4" foam pad. Once i get a BEC back, it will hang out on the driver's side of the plate. Undecided on redoing bed mounts to put it back on, but i need weight in back. I swear it feels close to 75/25 front to rear. Need shorter shock bodies up front, shes bottomed out in these pics. Rear just needs more weight on it Last edited by nharkey85; 09-15-2014 at 08:31 PM. |
09-22-2014, 09:29 AM | #36 |
still waiting on my BEC to come back from castle. guess for now I have to suffice with my son's 2s rubicon.
09-28-2014, 06:48 PM | #37 |
09-29-2014, 09:09 PM | #38 |
Rock Crawler Join Date: Sep 2009 Location: Spring, Texas
It looks great. I love the rusty wheel look and your ride height. I wish I could get mine down, but I guess my truck was meant to be a jacked up 4x4. |
11-16-2014, 10:55 AM | #39 |
havent updated in a while because there hasnt been anything to update until now. ordered 3link+panhard kit and some coilovers, once thats here and see if my shock length guess was any good, ill order up the 4 link and more shocks. moving on to the dark side of the force. EDIT: 11/21/14 - 80mm Ballistic Fab dual spring shocks are here. Tracking # for 3link shows only that it was created monday morning (11/17/14). So either that package never made it to the PO or they didnt have in stock what they said they did (RC4WD) Last edited by nharkey85; 11-21-2014 at 07:01 PM. |
12-02-2014, 11:02 PM | #40 |
3-link finally showed up. Ordered 4-link and 90mm Ballistic fab dual spring shocks. Got it all mounted up. Looking into ways of standing rear shocks up on the outside of the frame. 80mm front and 90mm rear give me a ride height i like. Also had thoughts of dovetail or truggy cage, and now as im posting i see flatbed Last edited by nharkey85; 12-02-2014 at 11:06 PM. |
yet another TF2 thread....... - Similar Threads | ||||
TF2 tips and tricks thread | 1BadJeepBruiser | RC4WD Trail Finder 2 | 109 | 03-29-2023 01:10 PM |
Dual Dingo build thread-My first build thread | juswin24 | Axial SCX-10 | 205 | 09-19-2013 12:42 PM |
Sharpe351's TF2 build thread... | sharpe351 | RC4WD Trail Finder 2 | 32 | 08-15-2013 04:57 PM |
not really a build thread more of a upgrade thread... | dragit | Axial AX-10 Scorpion | 16 | 07-02-2009 10:11 PM |
