03-19-2014, 08:41 AM | #1 |
Quarry Creeper Join Date: Jan 2012 Location: My house
| TF2 paint
Don't know if this is the right forum but just have a question: What paint is recommended to use to paint the TF2 body.... Also what putty do u guys use for cracks or holes??? Thanks |
03-19-2014, 09:47 AM | #2 |
I wanna be Dave Join Date: Jul 2010 Location: Toronto
| Re: TF2 paint
Tamiya TS series paints work well with proper priming. In fact, with proper prep, any spray paint will work well. I use a combination of Kneadatite, and Squadron White for filling. |
03-19-2014, 10:01 AM | #3 |
RCC Addict Join Date: Jul 2008 Location: Fox Valley WI
| Re: TF2 paint
I used Model Masters hobby grade laquer based primer and paint on mine. Check the Paint and Body section for more info.
03-19-2014, 12:54 PM | #4 |
Well only issue is that the closest HS for me is about 2hrs lol so just wondering if I go to lowes or Home Depot I can pic some primer or paint that will adhere to a hard body
03-19-2014, 01:25 PM | #5 |
| Re: TF2 paint You can. I think it's Krylon Fusion that's designed for plastic. High quality primer from Tamiya is infinitely better than anything from Home Depot though, as it's designed for their smaller static kits primarily, and goes on thin and smooth.
03-19-2014, 02:47 PM | #6 |
Rock Stacker Join Date: Feb 2011 Location: Washington DC
| Re: TF2 paint
I'm thinking of leaving mine unpainted (stock yellow) - any advantages/disadvantages to leaving it like this? If I am going to paint - i'll probably stick with yellow...but I'd rather not paint the entire body and mess it up! Last edited by littlebuddha; 03-19-2014 at 03:35 PM. |
03-19-2014, 03:28 PM | #7 |
Newbie Join Date: Dec 2012 Location: fryburge
| Re: TF2 paint
I use duplicolor paint shop pro paint an clear great to work in a body shop
03-19-2014, 06:28 PM | #8 |
Newbie Join Date: Feb 2014 Location: Oakland
| Re: TF2 paint
Rustoleum plastic primer with Rustoleum flouresent yellow, and yes of course Rustoleum clear coat. The bed liner is Rustoleum textured green. Then rust-all to age it all out.
03-19-2014, 08:44 PM | #9 |
Newbie Join Date: Jan 2014 Location: Canada
| Re: TF2 paint
I just painted mine and used Krylon for plastic Semi Gloss White and it did the job. |
03-19-2014, 09:17 PM | #10 |
Rock Crawler Join Date: Jul 2012 Location: Albuquerque, New Mexico
| Re: TF2 paint
I like the tamiya paint also.
03-20-2014, 09:25 AM | #11 |
I joined the Band! Join Date: Aug 2009 Location: Maryville, Tn
I use duplicate color perfect match automotive paint with great success with a good primer underneath. If u go this route u have access to some nice pearls and metallics. Only way I roll Sent from my SCH-I545 using Tapatalk |
03-20-2014, 09:44 AM | #12 |
Quarry Creeper Join Date: Jun 2009 Location: l.a.
I used house of kolor blue a little blue pearl and house of kolor clear for this one Sent from my SM-T217S using Tapatalk |
03-27-2014, 07:53 PM | #13 |
| Re: TF2 paint
Hi guys - I really like the yellow so I'm going with the Tamiya Spray Lacquer TS-34 Camel Yellow. I have one question though - if I am painting yellow and the body is already molded in yellow plastic, do I need primer? If so I'll be getting the Tamiya Spray Surface Primer/Plastic Metal - if not then I'd rather save the 7 dollars... Thanks in advance for the help! |
03-27-2014, 08:44 PM | #14 |
Rock Crawler Join Date: Feb 2012 Location: OC
| Re: TF2 paint
Thats what I did, just went to Lowe's and bought their good primer and a good white enamel, I then got a gloss (clear). I sanded and prepped the body in stages too, from 600-800 grit to 1200 to like 2000, got rid of all the flashing from the molding. I used the Tamiya putty to fill in the little cracks in the cab on the back part of the cab. I have got alot of compliments on the paint from the club. (WCRCC). Wish i can post pics, but you need to reg., to see the pics on their site. |
TF2 paint - Similar Threads | ||||
TF2 Paint help | Grumpster1980 | RC4WD Trail Finder 2 | 4 | 04-19-2012 01:29 PM |
