07-13-2014, 09:32 AM | #1 |
Pebble Pounder Join Date: Feb 2008 Location: Mid Mississippi
| Setting shift servo?
I hate to show my ignorance but I have burned up one shift servo all ready trying to set the EPA on it. I now have a second servo on the truck and am worried I'm gonna burn it up also. I'm almost to the point of just leaving it in low gear and running it like that. Any tips on setting it would be great. Thanks...
07-13-2014, 05:41 PM | #2 |
Rock Stacker Join Date: Jan 2014 Location: northern
Using a servo saver on your shift servo is a good idea. The trans doesn't always switch gears immediately so while it's in the process of shifting the servo saver will keep the servo from burning up Sent from my iPhone using Tapatalk |
07-14-2014, 07:00 AM | #3 |
RCC Addict Join Date: Jan 2011 Location: Razorback Haven
| Re: Setting shift servo?
Try to only shift when it's rolling. Also when you do shift, after it locks into gear listen to the servo and see if it's still making noise. If it is dial it back some.
07-14-2014, 08:15 PM | #4 |
Thanks for the tips. I may try a servo saver to try and take a little pressure off the servo.
Setting shift servo? - Similar Threads | ||||
shift servo | Be Nice | Vaterra Twin Hammers | 4 | 06-10-2014 02:27 PM |
Shift servo | eric113 | RC4WD Trail Finder 2 | 19 | 09-05-2013 09:22 PM |
best shift servo | ax10newguy | Vaterra Twin Hammers | 4 | 07-24-2013 02:49 PM |
Shift servo? | 09 Screw | Electronics | 5 | 03-01-2011 07:12 PM |
shift servo | 4-linkedWK | Electronics | 3 | 04-12-2008 09:06 PM |
