Thread: TF2 coupler replacement
Old 09-18-2014, 02:02 PM   #1
Default TF2 coupler replacement
Had this idea for replacing the coupler on the 2 speed transmission with a drive shaft. Unfortunately all the shafts I could find were too long. Sent my spare ultra scale shaft to Scalerfab to be shortened and here's the finished product. It was basically welded yolk to yolk.
tokdl is offline   Reply With Quote
Old 09-18-2014, 04:51 PM   #2
Default Re: TF2 coupler replacement
What's the point?
68_f100 is offline   Reply With Quote
Old 09-18-2014, 05:44 PM   #3
Scale is the point, genius.
Old 09-19-2014, 06:41 AM   #4
How well does it work if the transmission and t-case aren't perfectly in line?
High Cotton is offline   Reply With Quote
Old 09-19-2014, 06:46 AM   #5
Seeing as the trans and case are perfectly lined up via the original coupler and mounting holes for the trans and T-case in the chassis, that won't be a problem, however the new coupler are still universal joints and may not be welded together 100% perfectly, so they would offer some allowance if they weren't lined up 100%.
Ran it last night for about a half hour with no issues.
Old 09-19-2014, 07:42 AM   #6
That's no more to scale than the original part. No production truck has a drive shaft that short and 98% of 4wd pickup trucks don't use a divorced transfer case.
Old 09-19-2014, 08:03 AM   #7
Cool idea, it's one of those just cuz factors lol
Bogncrawl is offline   Reply With Quote
Old 09-19-2014, 09:20 AM   #8
Yes I know, but I'm planning to go flat belly or really damn close. It will more than likely not be perfectly straight any more that's why I asked.
Old 09-19-2014, 09:24 AM   #9
I gotcha. I don't think I could achieve much angle with this short coupler, but I have faith that I could get some, just as long as there's no forward or rearward moment of the T case and trans.
Old 09-19-2014, 10:45 AM   #10
I like your idea - it looks much better than the stock part. As long as the weld can hold up to the torque, it is definitely an improvement in my book.
Alpha Male is offline   Reply With Quote
Old 09-19-2014, 10:58 AM   #11
Thanks, I'm still cautiously testing it out. I also keep the factory coupler close by in case of a failure. It's just something a little different I wanted to try.
Old 09-22-2014, 07:37 PM   #12
That a matter of opinion. And so the hell what. Many things on your build I don't agree nor like very much or consider very scale at all either, but once again that's a matter of opinion. It looks better than that factory polished tube by far. You don't like it you know what you can do. < minus the smile.
I apologize I didn't mean to offend. I didn't realize what you were talking about at first. After looking at my truck I see what you mean about the polished shaft. You come real close. Looks pretty good after all.
Old 09-22-2014, 08:17 PM   #13
No need to apologize, every one is entitled to their opinion. No harm, no foul My apologies to you as well.
TF2 coupler replacement - Similar Threads
Gooseneck coupler. Double J Scale Accessories 22 11-21-2016 02:05 PM
Sensor motor coupler? Diablo666 Electronics 1 07-08-2013 11:18 AM
coupler joehein General Crawlers 6 12-13-2006 12:19 AM
rear drive coupler replacement? sgirt General Crawlers 10 05-11-2006 01:09 PM
