Thread: Help with front 4 link shocks
Old 09-29-2014, 07:25 PM   #1
Default Help with front 4 link shocks
So I linked the tf2...had some 100mm shocks for the rear and in my parts bin I had some left over vaterra shocks that are a little over 3.5 inches uncompressed. Well the rear works perfect but the front rides too high and is all down travel. What's everybody using up front? 90mm Kings? Got a comp in two weeks gotta figure this out!
jtessmer88 is offline   Reply With Quote
Old 09-29-2014, 07:46 PM   #2
Jus
Default Re: Help with front 4 link shocks
scx-10 shocks fit perfectly. I bolt the bottom on right next to the lower links.
Jus is offline   Reply With Quote
Old 09-29-2014, 08:07 PM   #3
You could go to a taller shock hoop and a stiffer spring. That should give you some uptravel and lower ride height while keeping the longer stroke of the 100mm shocks.
High Cotton is offline   Reply With Quote
Old 09-30-2014, 05:31 AM   #4
How about some pic with the 100mm shock in front?
1beatjeep is offline   Reply With Quote
Help with front 4 link shocks - Similar Threads
Front 4-link help!!! Pgambardella Axial SCX-10 10 03-21-2012 07:23 AM
3 link front 4 link rear? MaxxMc Losi Mini-Rock Crawler 7 04-03-2009 09:31 AM
IFS w/ 4 link front and 3 or 4 link rear. T-Man Traxxas Crawlers 6 10-26-2004 07:28 AM
