Thread: tf2 with 2 speed transmission and 2 speed transfer case
Old 10-29-2014, 05:25 PM   #1
Default (posted pictures) tf2 with 2 speed transmission and 2 speed transfer case
Tf2 with 2speed transmission and 2speed transfer case (Helios 2) so now I have 4 speeds to pick from
Rc4wd Trailfinder 2 with Helios 2 transfer case: Rc4wd Trailfinder 2 with Helios 2 transfer case - YouTube
Teasley4Crawlers is offline   Reply With Quote
Old 10-30-2014, 04:14 AM   #2
Default Re: tf2 with 2 speed transmission and 2 speed transfer case
Nice! Looks like it works well. My TF2 has only one speed - go.
Alpha Male is offline   Reply With Quote
Old 10-30-2014, 10:25 AM   #3
Thanks you don't really need 4 speeds but I just thought it would be cool to say I did it
Old 10-30-2014, 11:15 AM   #4
It's no different than an old Toyota mini-truck with a doubler!
Lentsnh2012 is offline   Reply With Quote
Old 10-31-2014, 04:44 PM   #5
The main reason for the 2 speed I broke my stock transfer case
Old 11-26-2014, 09:12 PM   #6
Video of the truck driving it self with the throttle trim set at 1/4 throttle in low/low gear with new Holmes hobbies 35t torque master pro
Tf2 driving itself - YouTube
Old 11-26-2014, 10:18 PM   #7
Do you still have the broken transfer case? PM me if you do.
Old 11-27-2014, 12:12 AM   #8
SO with using two servos you have to use two channels to shift it correct?
fr8cture is offline   Reply With Quote
Old 11-27-2014, 09:26 AM   #9
Default Re: (posted pictures) tf2 with 2 speed transmission and 2 speed transfer case
Would assume so. On for the trans and one for the helios.
Sent while I should have been wrenching!
2003EDGE is offline   Reply With Quote
Old 12-02-2014, 11:34 AM   #10
Yes I have a 4 channel remote two channels to shift the transmission and transfer case
tf2 with 2 speed transmission and 2 speed transfer case - Similar Threads
any experience with rc4wd bullet 3 speed transfer case? jebster General Scale Talk 10 02-05-2015 05:55 PM
