10-30-2014, 07:03 AM | #1 |
Quarry Creeper Join Date: Sep 2012 Location: Connecticut, USA
| Big time understeer...
Hey guys, I tried searching for understeer in the trail finder 2 brand specific tech, and came up with nothing, is there another place to look? My tf2 understeers like crazy.. I'm running pitbull growlers and soft foams, so they are very pliable. Yet the truck just plows through and turns like the tires are only at half the turning angle.
10-30-2014, 10:18 AM | #2 |
RCC Addict Join Date: Oct 2012 Location: Charleston South Carolina
| Re: Big time understeer...
It's just the nature of the beast. The knuckles don't have enough caster built into them to fix the "into-the-ground" steering. The soft tires and foams probably amplify the steering problem. |
10-30-2014, 11:40 AM | #3 | |
Rock Crawler Join Date: Sep 2009 Location: Spring, Texas
| Re: Big time understeer... Quote:
I'm having a similar issue with my TF2 because of soft tires and memory foams. The truck tends to push forward when I turn and the tires fold over. I'm going to change over to a harder tire and a stiffer foam. I probably should have just kept the stock wheels and tires. They seem to work well enough for what I do anyway. Last edited by Alpha Male; 10-30-2014 at 09:48 PM. | |
10-30-2014, 02:54 PM | #4 |
Thanks for the replies guys. I t would be nice if VP had some axles and knuckles for it. I miss my scx10... Guess ill have to get a new one! |
10-30-2014, 04:49 PM | #5 |
RCC Addict Join Date: Oct 2011 Location: Brighton UK
Have you fitted CVD's yet? They increase the steering dramatically. You could also go one step further with overdrive at the front/under drive at the back. As mentioned the tyres won't be helping but mine turns very well on mudslingers and CVD's. |
10-30-2014, 05:49 PM | #6 | |
I wanna be Dave Join Date: Aug 2004 Location: san jose
Do you have a link to the CVDS? THANKS | |
10-30-2014, 06:14 PM | #7 |
| Re: Big time understeer... |
10-30-2014, 08:48 PM | #8 |
Rock Crawler Join Date: Jul 2009 Location: Victoria Australia
| Re: Big time understeer... I'm interested in seeing how you do overs and unders in Yota diffs.
10-31-2014, 01:24 AM | #9 |
10-31-2014, 05:03 AM | #10 |
Quarry Creeper Join Date: Dec 2009 Location: West Alabama
Remove the transfer case from the truck, open it up and flip the input shaft 180. Put it back together, but mount it with the "input" shaft down (which should be pointing forward now). The trans coupler should bolt up (just now its going to an "output"). The rear axle is driven 1:1 by the trans, and the front is now overdriven by 1.47 IIRC. I recall several people doing this, and a few of those eating gears until they changed back |
10-31-2014, 04:46 PM | #11 |
10-31-2014, 05:15 PM | #12 |
11-01-2014, 01:53 AM | #13 | |
Pebble Pounder Join Date: Jun 2011 Location: Rio Brisbanero Australia
11-01-2014, 07:09 AM | #14 |
It's hard to tell the difference between 1.1 gearing/ 1.47 gearing. There is a slight difference, but not enough to perform better. If you are checking the gear ratio with the input and output, the output side might only be minutes of a degree off. |
Big time understeer... - Similar Threads | ||||
Big time thank you....... | evileddy420 | Colorado | 4 | 05-05-2010 08:51 AM |
EastEndMachining Steering linkage and servo mount = understeer? | neamerjell | HPI Wheely King | 4 | 03-24-2010 05:11 PM |
HELP!!...pushing/understeer | crud | Newbie General | 2 | 08-05-2008 01:05 PM |
Big Red Hits The Big Time | JEFF THE JET | Missouri | 14 | 07-09-2008 09:39 PM |
Need Help Big Time!!! | spin_master_06 | General Crawlers | 4 | 02-10-2006 04:33 PM |
