12-18-2014, 09:28 PM | #1 |
Newbie Join Date: Nov 2013 Location: Madison
| Leaf spring questions...
Hey guys. I posted in an earlier thread that I ordered the kit after lurking here forever. Finally got it and having fun with the build so far. Anyway, leaf spring questions: 1. Should I do all 3 on each axle? Seems to be an optional thing so wasn't too sure. I saw in the tips thread that somebody suggested using all 3 to prevent the leafs from getting bent. I also saw where somebody mentioned they soften up over time. FWIW, I'll mostly be trail driving with just a small amount on the rocks. 2. Should I put the smaller leafs on the bottom like on 1:1 trucks? |
12-18-2014, 10:19 PM | #2 |
Quarry Creeper Join Date: Dec 2013 Location: Pevely
| Re: Leaf spring questions...
i don't have a tf2 but I have a trail stomper and it has two leafs with the smaller one on bottom front and rear. I use it for trail runs mostly but I do have a few small rock piles to play on also and I'm happy with the performance. The leafs will get softer with some use so just drive it for a bit and if it doesn't work the way you want after a few runs then start taking out or adding leafs.
12-18-2014, 11:32 PM | #3 |
Quarry Creeper Join Date: Aug 2014 Location: sacramento
I would start with the main leaf and the second longest one under that
12-19-2014, 12:13 AM | #4 |
RCC Addict Join Date: Oct 2011 Location: Brighton UK
I wouldn't worry too much about it. Yes they do bed in nicely after a few hours. They will bend at some point, but you just remove and bend back to shape by hand and eye. I would use the larger leaf helper under the front ones and leave the rear as just the leaf. Once they soften with running you can add more if required. |
12-19-2014, 08:35 AM | #5 |
Thanks everybody. I was done building for the night right at this point and thought I'd ask you all first. I don't really have any friends that are into RC so it's nice to be able to bounce ideas off people here.
12-20-2014, 12:55 AM | #6 |
Quarry Creeper Join Date: Oct 2011 Location: Anchorage
I use the main leaf with the shortest helper underneath on the front and for the rear I have the main with the middle length one underneath it. Perfect ride height and articulation for me.
Leaf spring questions... - Similar Threads | ||||
RC Bros Leaf Spring kit questions? | goldmember | Axial SCX-10 | 22 | 12-12-2009 01:06 PM |
leaf spring questions | the kid | General Crawlers | 2 | 04-01-2007 06:45 PM |
Leaf spring shackle questions | MNorby | General Scale Talk | 4 | 03-23-2007 11:56 PM |
Hi-Lift leaf spring questions | STEEL_CITY_CRAWLER | General Scale Talk | 6 | 02-22-2007 11:02 AM |
Leaf spring questions/ measurements | BrandO | Tamiya TLT Crawlers | 10 | 01-30-2006 08:26 PM |
