01-27-2015, 09:19 PM | #21 |
Quarry Creeper Join Date: Aug 2014 Location: sacramento
| Re: 4 speed tf2 update
I'm not 100% sure what I want too do yet with the body probably something simple like two tone
01-28-2015, 09:31 PM | #22 |
Little more sanding
01-29-2015, 04:55 PM | #23 |
Got the body painted basic paint job, made a roll bar and land anchor
01-31-2015, 07:52 PM | #24 |
gsrcc 18
02-03-2015, 08:06 AM | #25 |
gsrcc 18
02-07-2015, 12:37 PM | #26 |
Moved the front axle forward 3/8 and moved the rear back 3/8
02-07-2015, 01:05 PM | #27 |
02-08-2015, 11:20 AM | #28 |
Got some bpc recovery ramps for the back of my truck
02-18-2015, 02:09 PM | #29 |
| Re: 4 speed tf2 update Bearing mod for yota axles This will work for tf2 (yota axles) and gelande (yota 2 axles) instructions will be a little different. Will need to buy 4-3x6x2.5 flanged bearings 4-longer bolts then stock knuckle hardware Take the front axle apart, get a 15/64 drill bit drill the bushing holes in the knuckles (I don’t drill all the way through), on the tf2 knuckles I cut the bushings down and put them on the inside of the knuckle, on the yota 2 axle I take the bottom bushing and put it on the top and cut down the top bushing and put it in the bottom so it sits between the housing and the knuckle. Then take a flanged bearing put one on the top and the bottom side of the knuckle and put the bushings in, get a longer bolts then the stock ones and mock it up, mark the bolt as close to the housing as you can, take it back apart cut the bolts down so they will make up for the extra height of the flange on the bearing and will catch all the thread on the housing to help them from stripping out and will be stronger. Put the axle shaft in and put the knuckle on and make sure the bolt doesn’t contact the axle shaft. If everything is good put the axle back together and Loctite the bolts and you should be good to go. |
02-22-2015, 10:56 AM | #30 |
Mrb fire and ice
02-22-2015, 04:50 PM | #31 |
Rock Stacker Join Date: Jan 2007 Location: Plattsburgh
Crazy articulation.
02-23-2015, 09:56 AM | #32 |
a couple videos from fire and ice at moon rocks https://www.youtube.com/watch?v=HqZod9qR4lo https://www.youtube.com/watch?v=emA4vW98YYg |
02-23-2015, 10:09 AM | #33 |
more pics of mrb fire and ice 2015
02-24-2015, 08:35 PM | #34 |
I wanna be Dave Join Date: Aug 2004 Location: san jose
Sweet rig. Is this going to make it to the GSRCC Scale Endurance 19? Hows that 4speed working? |
02-24-2015, 09:53 PM | #35 |
Yep it will be at gsrcc 19, and the 4 speed is working out great super low to technical spots, mid two gears for normal crawling, high for just going fast and sandy spots,
02-28-2015, 09:26 PM | #36 |
Gsrcc 19, 145 gate scale endurance
03-12-2015, 05:00 PM | #37 |
Got some lockedup rc wheels and crawler innovations foams
06-15-2015, 09:16 AM | #38 |
Quick tip: use leaf spring shims to get your pinion angle right, then use second set on top of leafs to make the screws sit flat and adds more support so the leafs don't bent and break as easy.
12-31-2015, 02:47 PM | #39 |
Quarry Creeper Join Date: Jun 2010 Location: casper
Sweet truck I just ordered me a Helios 2 speed transfer case gonna have to try the bearing mod next
01-02-2016, 02:11 AM | #40 |
Yeah I miss this truck, the Helios doesn't bolt right up but isn't to hard to make it work, the hardest part is making the coupler between the transmission and it. Bearing mod definitely worth doing.
4 speed tf2 update - Similar Threads | ||||
Chino63/1BJB 1:1 Bruiser/TF2 update 5/2/14 | 1BadJeepBruiser | 1:1 Full Size Vehicles | 51 | 04-27-2017 07:06 AM |
tf2 with 2 speed transmission and 2 speed transfer case | Teasley4Crawlers | RC4WD Trail Finder 2 | 9 | 12-02-2014 10:34 AM |
little update of my TF2 | JakeTF2 | RC4WD Trail Finder 2 | 9 | 02-12-2014 10:25 AM |
Grims TF2 Update | Grumpster1980 | RC4WD Trail Finder 2 | 5 | 10-24-2012 01:30 PM |
