01-31-2015, 06:40 PM | #1 |
| Stock Mirrors, A Possible Fix
Don't know if anyone has tried this, but I think I might have found a fix for the stock mirrors popping off. Given this crowd, someone likely has already tried this... I screwed up the body my TF2 came with and planning on getting another one and starting fresh. So, I figure there is no reason not to experiment with this one and use what I learn on the next one. GreatScott's Great Trail Finder Basically, I bolted the mirrors on. I used 2mm cap screws from Losi MRC stock beadlocks (the fake ones), with a 3mm washer. I drilled from the inside out very carefully using a 1/16" bit (slightly smaller than 2mm), did not want to go all of the way through. Using my electric screwdriver I ran the screw in most of the way, then hand tightened it so that it did not strip. The end result looks ok, and should hold the mirror on a lot better than glue. I did not drill all of the way through, from the outside you can't see anything different. When I get some trail time on this truck and start banging the mirrors against stuff, I'll let you know how this worked. Last edited by Greatscott; 01-31-2015 at 06:43 PM. |
01-31-2015, 09:52 PM | #2 |
Pebble Pounder Join Date: Jan 2015 Location: Hopewell Jct
| Re: Stock Mirrors, A Possible Fix
Curious to see how they perform out on the trails. I had just done this to mine the other day My first TF2 Very simple mod but seems to be a big help! |
02-02-2015, 04:52 AM | #3 |
Pebble Pounder Join Date: Jun 2011 Location: Rio Brisbanero Australia
Its a good idea, but you will just snap the mirror of the base before to long the rubber mirrors are the go |
02-02-2015, 05:57 AM | #4 |
Rock Crawler Join Date: Sep 2013 Location: New Orleans
Just ordered a set of the rubber mirrors, hoping you're right. |
Stock Mirrors, A Possible Fix - Similar Threads | ||||
HB rover stock foam fix | Matt, | Tires and Wheels | 7 | 08-26-2011 02:17 PM |
Stock Driveshaft fix | Positronic | Axial AX-10 Scorpion | 8 | 01-28-2009 07:35 PM |
fix that broken stock wheel | bennett-racing | General Crawlers | 1 | 01-16-2006 11:24 AM |
