02-27-2015, 08:28 PM | #1 |
Newbie Join Date: Mar 2014 Location: River Falls
| Is the suspension supposed to be this crooked?
So I got my truck today, bought it used, and started going through it. First thing I notice is the front suspension isn't close to symmetrical. Is this normal? It does have 3 link front 4 link rear. |
02-27-2015, 08:47 PM | #2 |
Quarry Creeper Join Date: Oct 2011 Location: Anchorage
| Re: Is the suspension supposed to be this crooked?
No that is not normal or even close to it at all. Check the links and see if one side is shorter than the other. That might be the reason why it's off...
02-27-2015, 08:54 PM | #3 |
Pebble Pounder Join Date: Jan 2015 Location: Hopewell Jct
I was thinking the same thing. Some where the lengths are wrong and are offsetting the alignment. Here are the instructions, Confirm/check where it differs http://rockycountry.com/product/Inst...structions.pdf |
02-27-2015, 09:04 PM | #4 |
Rock Crawler Join Date: Sep 2013 Location: New Orleans
From those photos, it looks like one of the steering links is bent, and the primary steering link is way too long, throwing your entire geometry off.
02-28-2015, 04:01 PM | #5 |
Lol so I'm guessing that this is some Janky China kit. Doesn't look like The pictures at all and the lengths aren't even close. How important are the angled rod ends?
02-28-2015, 04:02 PM | #6 |
| Re: Is the suspension supposed to be this crooked? |
02-28-2015, 06:02 PM | #7 |
Quarry Creeper Join Date: Dec 2009 Location: West Alabama
That is not how my links were labeled in the 3/4 link kits. Nor did the kits come with metal ends. Looks like someone "built" links from parts Also that panhard bar is too short, so its forcing the axle off-center |
02-28-2015, 06:10 PM | #8 |
The lower links are probably fine. The panhard bar is way off. Have you made links before? It's really easy... stainless steel 8:32 (I'm really tired and fuzzy right now but I believe that's it) threaded rod, .25" steel or aluminum tubing, Traxxas Revo rod ends and tools. Last edited by johnnyh66; 02-28-2015 at 06:14 PM. |
03-01-2015, 07:11 AM | #9 | ||
| Re: Is the suspension supposed to be this crooked? Quote:
Thanks for the input! I'm taking this out tomorrow. I switched two links around and it got better. Still garage but better! Can you send me a pic of your steering servo horn worth link please? Quote:
I'm going to try this if I fail I'll just have to buy a 3 link setup. Do I drill the tubing or will the hallow tube be the perfect size? I bought some alum tubing in the past and it was VERY thin walled. | ||
03-01-2015, 07:17 AM | #10 |
I'll get you a pic of my front end in a few. The tubing slides right over the threaded rod perfectly, and doesnt need to be thick walled. The threaded rod provides the strength, the tubing lets it slide easily |
03-01-2015, 08:31 AM | #11 |
Ride height Extended |
03-01-2015, 09:43 AM | #12 |
03-01-2015, 09:54 AM | #13 |
Quarry Creeper Join Date: Dec 2013 Location: Pevely
There is a thread titled How to make your own links in the tools and procedures sections near the top of the forum page. It should have all of the info you need to make you an expert on link building in short order. |
03-02-2015, 10:44 AM | #14 |
Newbie Join Date: Jan 2015 Location: Houston
How long are your front shocks? The links are most likely set up for stock length shocks so with longer shocks the panhard bar is too short so it shifts the axle to the passenger side. If you fully compress the front suspension does it line up straight? If it does then you just need to lengthen the panhard bar. One thing to note about lengthening the panhard bar is on full compression it will shift the axle slightly to the driver side. I'm actually in the process of dealing with this on my TF2, I am working on making taller shock hoops (since the Gelande 2 hoops are sold out) to lower my front end down to close to stock height and bring the geometry back to what it should be.
03-03-2015, 11:21 AM | #15 |
The front shocks are 90mm. I don't care for them. I want to replace them. Here is the back. 100mm king knock offs? |
03-03-2015, 11:26 AM | #16 |
So here is my new goal... I need to get shorter front shocks and keep stock length links. I want to articulate like its my job. What should I get? I'd like to match the rear if possible but am not committed to them. I will have to adjust them I know for sure. I need to get an interior and need to lift the body (which the kit is impossible to find) to clear my outcry esc. I have 1.9 proline swampers but need better wheels. Any suggestions? |
03-05-2015, 07:43 AM | #17 |
03-05-2015, 07:46 AM | #18 |
Those are axial icons. Fronts are completely stock except for not using the short spring. Rears are mounted using front shock hoops and longer lower ends, and without the short spring. Front is right at 90mm and needs internal limiting. Rear is about 95mm and has about 5-7mm external limiting
03-05-2015, 09:56 AM | #19 | |
So I put new links in, with these arb shocks and when I turn the camber is all messed up and i can barely turn the tires. The servo seems to get jammed up. The tires at the top push away front the truck. I'm frustrated with this pile. Should I just return this to lead springs and 80mm front shocks? Or am I missing something. | |
03-05-2015, 11:10 AM | #20 |
Have patience. I will try to measure all my links eye-to-eye so you can figure out where yours are different As far as shock rub, with certain wheel/tire combos the top of the tire touches the spring at full compression and the spring touches the axle side panhard mount |
Is the suspension supposed to be this crooked? - Similar Threads | ||||
Crooked then Straight | RickM | Axial AX-10 Scorpion | 9 | 11-15-2010 03:31 PM |
4 linked it and I think its crooked | RickM | Axial AX-10 Scorpion | 10 | 03-10-2010 11:51 AM |
crooked axal | jwilli2213 | Axial AX-10 Scorpion | 11 | 02-12-2008 10:29 AM |
