03-17-2015, 03:34 PM | #1 |
RCC Addict Join Date: Aug 2007 Location: Seattle
| Abort mission
Bought a used tf2 and it won't be here for at least a week so I did what any normal person would do.. Bought a ton of parts that will hopefully fit. Plans include: Over under transfer case mod 3 link front with leaf spring rear jr 8711 Tekin rx8 Home made hand wound 45t 3s Samurai body with 210mm wheelbase Shortened chassis Possibly running the 2 speed tranny with the motor in the rear of the chassis. Last edited by djjiz; 05-05-2015 at 11:06 PM. |
03-23-2015, 07:38 PM | #2 |
| Re: Challenge accepted
Moving onto plan b. There's no way in hell I'll be able to shorten this enough so a Proline Comanche will take its place. How long you think this output will last? |
03-26-2015, 02:34 PM | #3 |
Anybody have any tricks to gain up travel with a 3 link? The centering rod makes contact with the upper link mount and I can't see how I can fix that without bending things.
03-26-2015, 02:36 PM | #4 |
Pebble Pounder Join Date: Jan 2015 Location: Hopewell Jct
Pics of how it is hitting? Mine doesn't make contact with anything and i get full compression.
03-26-2015, 02:40 PM | #5 |
Bruiser shackles installed with some modifications but they were easy enough to not document the process. And here's some half assed pics of the centering link in question. |
03-26-2015, 02:43 PM | #6 |
| Re: Challenge accepted |
03-26-2015, 02:45 PM | #7 |
Quarry Creeper Join Date: Jun 2010 Location: lexington nc
not sure but maybe the panhard bar needs to b mounted on the other side at the frame end lookin from the side looks like it go from front to back a lil bit
03-26-2015, 02:46 PM | #8 |
Your links may not be in the right spot on the bracket, possibly on the frame as well. I had the same problem in the beginning and had to shift a few things around. This is how mine are and work great. Keep in mind, shocks get mounted on the front side of the axle now too |
03-26-2015, 02:47 PM | #9 |
The upper bracket on the cross link i have straddling the shock hoop. So screw in middle behind shock and other on the rear side on the shock hoop.
03-26-2015, 02:53 PM | #10 |
Looks like my axle is pushed too far forward?
03-26-2015, 02:57 PM | #11 |
you have some of the front frame cut off and are using different shock hoops. I think that is making it difficult to get an accurate count. try moving the link to the other side as i have edited your picture to show. everything else may be ok. try that to start |
03-26-2015, 03:03 PM | #12 |
That's the way I received it including the link forward on the chassis mount. Gained one millimeter at best mounted the current way. I might be expecting too much from this setup. If I redesign a new axle truss/ upper link mount I'll gain more travel. |
03-26-2015, 05:28 PM | #13 |
Progress. Shocks mounted and suspension cycles smoothly. Looking forward to the leafs breaking in.
03-26-2015, 06:11 PM | #14 |
And a pic with a body I'll never use.
03-26-2015, 06:16 PM | #15 |
I don't like it at all. Don't use it.
03-26-2015, 06:41 PM | #16 |
I wish this body wasn't on everything. It's nice but extremely played out.
03-26-2015, 07:06 PM | #17 |
Moose knuckle hood scoop extraction was successful. Wish I had a before picture. It went up almost half the height of the windshield.
03-26-2015, 07:30 PM | #18 |
Pics of the junk in the trunk.
03-26-2015, 07:53 PM | #19 |
Heres the look im going for. Its a friends rig and im gonna surprise him with the build. Body should be here tomorrow.
03-27-2015, 01:39 PM | #20 |
Rock Crawler Join Date: Feb 2011 Location: Spur, TX
I'm willing to bet that rear output will last long enough for you to put a Pro4 and 4s power to it. Remember to get it on camera or it didn't happen! ...The parts gremlin made me say it. |
Challenge accepted - Similar Threads | ||||
Accepted wheelbase? | TLZ | 2.2 Scale Rigs | 4 | 02-05-2014 04:56 PM |
RECON G6 Challenge VP's Pumpkin Pie & Pilgrims G6 Challenge | DRIVNMF | Recon G6 | 146 | 11-17-2012 09:47 AM |
I Have A Challenge For Someone... | Rudukai13 | Chit Chat | 14 | 03-20-2007 08:59 AM |
