Thread: 2003EDGE's TF2 Mojave II Buildup
Old 10-05-2015, 07:29 PM   #1
Default 2003EDGE's TF2 Mojave II Buildup
Here she is! The new TF2 Mojave II kit. David (new2rocks) has covered the differences in the body of this kit. That is where the most visibly notable changes were made. However, there are some noteworthy changes that have been made in the drivetrain as well. We will get to those in a moment.
The idea behind this build is to put the RC4WD TF2 guide to use! I will be phasing through leaf spring setups to links and so on and so forth.
Lets get going here!
Great packaging as usual!
Here is the crown jewel...but will set that to the side as we have more important business to tend to!
I have this KNK Hardware kit for the TF2 that I will be using for this build. Nothing wrong with the factory hardware other than I wanted the stainless setup for this build.
Nice to see that the hardware and kit pieces are clearly labeled for ease of assembly.
Pretty standard build up to this point. Make sure to use threadlock in all metal to metal connections.
Here is what the inside of the transfer case looks like straight from the box. Note that there is a little grease in there...but we want to put a better coating on the gears. Don't completely fill the case but I like to use a healthy amount.
We have the same story inside the transmission. There is a light coating of grease but make sure to add some more for reliability and longevity of the gears.
One common step in building the TF2 is to shim the gears in the axles. I am happy to note that in my kit they were shimmed properly from the factory. I added some grease to the gears and closed them back up.
So, after a couple short hours, here as where we are at. Will pick up on this again tomorrow!
2003EDGE is offline   Reply With Quote
Old 10-05-2015, 09:09 PM   #2
Default Re: 2003EDGE's TF2 Mojave II Buildup
Yessir...keep it coming...
new2rocks is offline   Reply With Quote
Old 10-06-2015, 10:08 AM   #3
Curious to see what these are!
Also what kind of grease are you using?
norco kid is offline   Reply With Quote
Old 10-06-2015, 10:10 AM   #4
The axles appear to be shimmed properly from the factory. I have spoken with another team member and his were shimmed properly as well. The gears in the transmission appear beefier than my past TF2 rigs as well.
I am using Lucas Red and Tacky grease.
RC4WD Team Driver*Krawl Off-Road
Old 10-07-2015, 10:30 AM   #5
I just built the same kit. Only the gears in the front axle needed shimmed.first kit and tf2 I've done. Easy to follow instructions. Look forward to seeing how yours turns out.
etanthegreat138 is offline   Reply With Quote
Old 10-11-2015, 08:13 AM   #6
Ok, so it looks like they may have missed a few axles....will tear the front down and get a pic or 2.
Old 10-11-2015, 08:17 AM   #7
Got the truck into roller form. Wheels went together very easily. Just took my time. Now to this body!
Old 10-18-2015, 04:14 PM   #8
Looking good!!
Tontos_Touch is offline   Reply With Quote
Old 10-18-2015, 04:15 PM   #9
Thanks! Will have some more updates on the build shortly!
Old 10-18-2015, 06:54 PM   #10
I can't wait to hear your thoughts about the 3/4 link, I have one with stock Springs an my other one has red Springs, I thought about cutting the eyes off the stock Springs an applying the under the reds but it may be to stiff, still waiting on the g2 shock hoops or I may go with the axial ones
Old 10-25-2015, 07:29 AM   #11
I just got this same truck today
It's my very first crawler
Of corse I have lots of Rc cars
Just my first crawler so what can I expect
From this thing
Kx450 is offline   Reply With Quote
Old 10-25-2015, 07:31 AM   #12
It is a great kit! There are a couple small issues with the body but nothing that can't be worked around. As for driving it once it is built, the leaf spring suspension will take some trial and error to learn how to make it work to your advantage. But that is what makes this truck a blast to drive.
Old 10-25-2015, 04:29 PM   #13
You can still get it at tower and rpp. Don't know why rc4wd isn't selling them.
Old 10-25-2015, 04:31 PM   #14
They have stock they are selling, will see what I can figure out.
Old 10-26-2015, 06:35 PM   #15
Coming along great
Im going to follow your build
Can you suggest a good servo for the tranny?
Like maybe a small micro servo?
Thanx
HARDRIVE is offline   Reply With Quote
Old 10-26-2015, 06:51 PM   #16
I will be running a Hitec HS225MG servo for shifting duties. It is a small servo and more than enough torque for shifting duties.
Old 10-26-2015, 07:18 PM   #17
Thanx man ill order that servo
Old 10-29-2015, 02:59 PM   #18
Mmmmmmmmm TF2 goodness
BadWagon is offline   Reply With Quote
Old 11-22-2015, 06:06 PM   #19
Updates????
Jeepfixer1 is offline   Reply With Quote
Old 12-23-2015, 06:22 PM   #20
Natedog's Avatar
X2...........................................
2003EDGE's TF2 Mojave II Buildup - Similar Threads
2003EDGE's TF2 "Lil Bit" 2003EDGE RC4WD Trail Finder 2 6 01-01-2015 07:25 PM
