12-26-2015, 08:01 PM | #1 |
Quarry Creeper Join Date: Oct 2015 Location: Wisconsin
| SWB Bronco spare parts build
So I literally bought the tf2 short wheel base to use up some spare parts and because I love early broncos. This won't be much of a build.. just more of a picture thread. Ordered the body today! Sent from my SM-G920R4 using Tapatalk |
12-28-2015, 05:59 PM | #2 |
| Re: SWB Bronco spare parts build
Sweet! Which bronco body in particular?
12-28-2015, 10:59 PM | #3 |
Rock Stacker Join Date: Sep 2015 Location: US
What are those tires Sent from my XT1042 using Tapatalk |
12-29-2015, 08:16 AM | #4 | |
| Re: SWB Bronco spare parts build Quote:
The tamiya one Rc4wd mud thrashers Sent from my SM-G920R4 using Tapatalk | |
12-29-2015, 06:34 PM | #5 |
| Re: SWB Bronco spare parts build I need to push the wheelbase out a tad Sent from my SM-G920R4 using Tapatalk |
12-29-2015, 08:42 PM | #6 |
| Re: SWB Bronco spare parts build |
12-30-2015, 07:35 AM | #7 |
I'm guna get rid of the front leafs and go coil springs. That should allow me to stretch it out a bit Sent from my SM-G920R4 using Tapatalk |
12-30-2015, 02:47 PM | #8 |
Or you could use u-bolt kit and only one of the two holes in the springs to locate the axle fore/aft. Or you could make a tiny lift block spacer, maybe 3mm thick with countersunk mounting screws in it and offset the two stock leaf holes for axle mounting?
12-30-2015, 03:38 PM | #9 |
01-11-2016, 08:40 PM | #10 |
Been working on the bronco. Went to a three link front. Still have to make a panhard Sees to have a lot more articulation like this and with different shocks Sent from my SM-G920R4 using Tapatalk |
01-11-2016, 08:58 PM | #11 |
Yes, Bronco was coil front and leaf out back. You're mocking up now and will make thicker link mount plates for front axle?
01-11-2016, 09:32 PM | #12 |
Rock Stacker Join Date: Dec 2010 Location: Golf course
what bumpers are you going to go with? the ones pictured look a bit narrow. i love EB's as well!!
01-12-2016, 05:49 AM | #13 | ||
Sent from my SM-G920R4 using Tapatalk | ||
01-12-2016, 09:41 AM | #14 |
What you're using is fine for design and test, but at least 1/16" thick for final pieces. Also some triangulation from the link mount screws to the axle is necessary unless it's a thick machined piece.
01-12-2016, 10:04 AM | #15 |
Sounds good, I will be triangulating the mounts out on the final pieces Sent from my SM-G920R4 using Tapatalk |
01-12-2016, 04:39 PM | #16 |
| Re: SWB Bronco spare parts build Will have to get some steel one of these days to make the final mounts but the links are done Sent from my SM-G920R4 using Tapatalk |
01-14-2016, 02:26 PM | #17 |
Out of curiosity what are you cutting metal with natedog, die grinder? Sent from my SM-G920R4 using Tapatalk |
01-19-2016, 06:12 PM | #18 |
Some minor tweaks on the chasis and finish the body and it's done! Sent from my SM-G920R4 using Tapatalk |
01-20-2016, 12:24 AM | #19 |
I wanna be Dave Join Date: Apr 2014 Location: North Carolina
01-20-2016, 04:59 AM | #20 |
Gotchya, and thanks. Sent from my SM-G920R4 using Tapatalk |
SWB Bronco spare parts build - Similar Threads | ||||
Spare parts build into whatever it becomes | Pavmentsurfer | Axial SCX-10 | 5 | 03-30-2015 10:52 PM |
...spare parts build... | Leprasol | Axial SCX-10 | 14 | 05-25-2011 08:45 PM |
Spare parts build.... | ddiaz10240 | 1.9 Scale Rigs | 1 | 08-26-2008 11:30 PM |
