Thread: RC4WD Badges?
Old 01-16-2016, 09:58 AM   #1
Default RC4WD Badges?
Hey guys, just picked up some metal badges from RC4WD/CCHAND and noticed that there is no adhesive backing to them, only metal.
What did you guys do to fit them on your TF2s? I might try super glue but I am concerned that it will be messy and uneven....
Ghost Koi is offline   Reply With Quote
Old 01-16-2016, 01:08 PM   #2
Default Re: RC4WD Badges?
I used some fast set ca glue on mine, I put them on a piece of blue painters tape added a thin layer of glue and stuck them on, allowed them to dry and bam! The tape is just a way to help you hold them so you don't glue them to your fingers and next thing you know your a hilux4X4
Before (sanded down for a more flush look)
After (just test fitting before paint)
Lost_Frequency is offline   Reply With Quote
Old 01-16-2016, 01:51 PM   #3
I use canopy glue. dries clear and sticks ok if it is a very clean surface, but at the same time you can remove it later if you want without damage to the body.
Habanero is offline   Reply With Quote
Old 01-16-2016, 02:18 PM   #4
Thanks, I'll try using painters tape tonight...
+1 for not becoming a Hilux4x4
Old 01-16-2016, 06:10 PM   #5
CA works fine, and an x-acto blade behind will take it off if needed. I like a medium to thick CA for this type of application so that it doesn't run and maximizes the contact area.
new2rocks is offline   Reply With Quote
Old 01-16-2016, 07:06 PM   #6
Nice trick using painters tape to keep the glue off the emblem and fingers...makes me wonder why I didn't think of that, lol.
SteveC6R is offline   Reply With Quote
Old 01-16-2016, 07:25 PM   #7
One question about the painter's tape... if it is placed over the badge, how do you align it with the truck properly? Would you just remove the tape first and then hope the glue hasn't dried before that?
Old 01-17-2016, 12:47 AM   #8
Well if you do a light layer an keep the side that your working on facing up its just to aline an let it dry as long as you keep the glue off of the tape then your good to go
Old 01-18-2016, 01:03 PM   #9
Well, they ended up not working out... Does anyone know where I could find some with an adhesive backing?
Old 01-18-2016, 06:57 PM   #10
I picked up a set from ebay not metal but plastic with a clear layer over includes 2 toyota 4x4 2 hilux 4x4 and a toyota grill emblem for around $13 canadian i think the seller was customcuts from germany they are adhesive backed and fit nice
scalemadness is offline   Reply With Quote
Old 01-18-2016, 07:06 PM   #11
I always use a thin layer of E6000 or shoe goo. Works brilliant
Bananaclip is offline   Reply With Quote
Old 01-18-2016, 07:07 PM   #12
Here u go Emblems and Badges
teamreedracing is offline   Reply With Quote
Tags
trail finder 2
RC4WD Badges? - Similar Threads
Fender Badges arnesto RC4WD Trail Finder 2 2 04-30-2013 12:51 AM
