09-29-2016, 10:15 AM | #1 |
Quarry Creeper Join Date: Oct 2015 Location: Wisconsin
| Multiple axle failures...
I have a swb tf2. The drivers front axle keeps breaking in the hub. I had hours of run time and now within 2 hrs I have two of the same failures and the second time it looks like the bearing failed. Anyone run into this before. I can't think of anything I would have changed to have this problem. Sent from my SM-G920R4 using Tapatalk |
09-29-2016, 05:16 PM | #2 |
| Re: Multiple axle failures...
Ouch. Bent axle housing? Site through it with both knukcles and axles removed. Loose, sloppy worn out knuckle bearings?
09-29-2016, 06:41 PM | #3 |
Rock Crawler Join Date: Nov 2014 Location: Dells
too much steering. You should helicoil the knuckle mounts too. And buy some XVDs. |
09-30-2016, 10:12 AM | #4 |
That's what I was wondering. I did get some clicking at full lock. This didn't happen when I was running rc4wd mud thrashers but it happened on both tsl boggers and proline super swampers Sent from my SM-G920R4 using Tapatalk |
09-30-2016, 05:04 PM | #5 |
More grip, bigger tires. Even 1/1 jeeps have that issue. |
10-03-2016, 07:19 PM | #6 |
Rock Crawler Join Date: Jul 2005 Location: Spartanburg
As previously stated, check the endpoints on your steering. Over steering will blow dogbones apart in a hurry. All of the force gets put on the very end of the cup where it is weakest and this is one result. RC4WD Team Driver*Krawl Off-Road |
Multiple axle failures... - Similar Threads | ||||
How to diagnose servo failures and (hopefully) repair them. | Andsetinn | Electronics | 13 | 11-27-2013 09:32 AM |
Locker/Spool failures.. | mrdrinksalil | Losi Mini-Rock Crawler | 6 | 04-17-2009 11:16 AM |
Towerpro servo failures?? | holycaveman | Electronics | 36 | 02-15-2008 01:24 AM |
Novak Goat Failures? | TunaMaxx | Electronics | 33 | 11-20-2007 04:00 PM |
