05-22-2017, 07:44 PM | #1 |
Rock Crawler Join Date: Apr 2017 Location: US
| Axle pinion shims
I need to shim my axle pinions on both axles before I install them. All I can find is rc4wd z-s 1559 that are .03 mm thick. Is there any other sizes of shims to use or I'm missing something.
05-22-2017, 09:09 PM | #2 |
Pebble Pounder Join Date: Aug 2011 Location: gaylord
| Re: Axle pinion shims
Z-s0290 is and assortment pack.
05-22-2017, 09:10 PM | #3 |
05-22-2017, 10:06 PM | #4 |
Awesome, thanks I'll look into it now
05-23-2017, 07:32 PM | #5 |
Newbie Join Date: Jan 2005 Location: Metro Detroit
I used a 3 Racing shim kit. The shims are 5x8mm and come in 0.1, 0.15, 0.2, 0.25 and 0.3mm thicknesses and worked perfectly on my TF2. HTH and good luck. Tim |
05-24-2017, 10:04 PM | #6 |
Definitely need luck if im ever to finish this build, lol. I did stop by a lhs thats more scaler friendly and picked up some different shims. Pretty excited to find some locally. So if the weekend treats me good hoping to get the axles gone through and mounted.
Axle pinion shims - Similar Threads | ||||
Rear Pinion Shims | totallypro | Axial Yeti | 7 | 02-25-2016 06:54 PM |
Check your pinion shims. | pro mod steve | Axial Yeti XL | 4 | 12-09-2015 08:29 AM |
Anyone else have 6 rear pinion shims? | Diablo169 | Team Losi Comp Crawler | 2 | 07-13-2009 04:26 PM |
Pinion shims | Joat | Tamiya CR-01 | 2 | 05-14-2008 10:13 PM |
