06-14-2017, 03:42 PM | #21 |
RCC Addict Join Date: Feb 2016 Location: Princeton, North Carolina, USA
| Re: My first hardbody - TF2 LWB with LC70
That came out really nice! I'm planning on adding hinges for the doors and hood on mine, as well as the interior, but it'll sit now until after vacation.
06-15-2017, 01:23 PM | #22 | |
Quarry Creeper Join Date: Aug 2016 Location: The Netherlands
| Re: My first hardbody - TF2 LWB with LC70 Quote:
I was contemplating that as well, but decided to build it as is first. I think it should be well doable on the hood, but am skeptical about the doors. The little screws around that area really seem to hold everything together. Anyways, today I mutilated a hinge to connect the body to the chassis. Also converted the front over to spring under axle, and quickly fabbed up some shock hoops to test different setups, see where I want to end up. I really had to mount the servo way higher to stop the axle from hitting the servo arm due to my low ride height. Really quite happy about the stance of the truck now. Just noticed a tiny bit of rubbing though on the front arches, so might have to go with slightly smaller tires. Thinking about Mickey Thompson Baja MTZ's. Let me know what you think. | |
06-15-2017, 04:35 PM | #23 | |
Stance looks perfect for stock scale, I agree the tires are a bit large for that look though. They still don't look monster truckish tho Sent from my SM-G930R4 using Tapatalk | |
06-15-2017, 04:36 PM | #24 | |
06-19-2017, 10:21 AM | #25 | |
They wouldn't be much smaller, so I doubt that would be an issue. Anyways, ran into too many complications to run the spring under axle in the front, but with the higher shock hoops I managed to get it low enough with the springs in the stock location. I've also changed my mind about the hinge in the back. Instead I've cut up some old hardware so I can just clip on the bodymount in the front (it pivots around this now), and then attach the back with some Velcro. Gave all the electronics a place for now (will likely be moved around again for the interior). Also moved the shifting servo all the way to the back to make room for the interior, and made a longer link from some threaded rod. Last thing for now is that I cut up the stock rear bumper to make it fit around the back of the LC70 bed. It had to be lowered quite a bit. | |
06-21-2017, 08:13 AM | #26 |
Spent last night soldering up my LED's. Went with warm white for the main headlights, and bright white for the fog lights. Also added all the indicator lights and hooked them up to a switch. Took the truck out for its first run this afternoon, and I must say it did great. Not as capable as my SCX 10 II, but a lot better than expected. Might have to go for a low profile skid in the future though, as expected. Some pictures from this afternoon. Last edited by IVIaarten; 06-21-2017 at 08:37 AM. |
06-21-2017, 08:36 AM | #27 |
RCC Addict Join Date: Aug 2008 Location: Paulina
Great job on the build. Really like that color and body.
06-22-2017, 02:52 PM | #28 |
| Re: My first hardbody - TF2 LWB with LC70 |
06-22-2017, 04:46 PM | #29 |
That's my dream truck, need to get one now!
06-23-2017, 12:39 AM | #30 |
Turned out awesome to be sure! Great job!! Sent from my SM-G930R4 using Tapatalk |
06-23-2017, 01:44 PM | #31 |
Quarry Creeper Join Date: Dec 2012 Location: ontario
| Re: My first hardbody - TF2 LWB with LC70 On Your Build !
06-24-2017, 01:40 PM | #32 | |
| My first hardbody - TF2 LWB with LC70 That's a big compliment, thanks. I'd say, go for it! Quote:
Thanks as well! I didn't like how far back the front windshield was sitting on this body (has been fixed in the v2 as I understand it), so I decided to fix it. I cut up the lexan panel on the inside, giving me some more room to move it around and get it sitting well. After I was happy with it I also added the windshield wipers. | |
06-24-2017, 05:52 PM | #33 |
I wanna be Dave Join Date: Apr 2014 Location: North Carolina
Looking great, sir. I like the lowered ride height - much better than stock TF2 for this body. Well done!
06-25-2017, 12:51 PM | #34 | |
Thanks for the compliment. Just a slight rubbing issue with the front tires to sort out. But this weekend, I started on my interior. Started out with CAD (cardboard aided design) Transferred to 1mm styrene, and cut to size. Heated, bent and glued down (going to do cleanup when it's fully cured. Placed in the body, mounted with 2 small screws. This'll give me the platform to base the rest on. | |
06-27-2017, 01:48 PM | #35 |
Also..... apparently if you have a single cab, a low bed, and want a full interior..... you have VERY little room for electronics! Managed to fit it in though, and it's a fun coincidence that the ESC is now sitting behind the grille, sort of like a radiator |
06-28-2017, 02:31 PM | #36 |
Question; I really want to shorten the wheelbase in the rear by about a cm. Seems to me the easiest way to do this is to drill some extra holes in the leaf springs. Am I right, or is there a better way to do this?
06-29-2017, 10:44 PM | #37 |
Newbie Join Date: Nov 2015 Location: St. Peters
Rc4wd(at least I think it's them) has a u bolt kit that will let you slide the axle on the springs.
06-30-2017, 06:14 AM | #38 | ||
Leaf Spring Mount for TF2 LWB Chassis and Toyota LC70 Body | ||
06-30-2017, 06:19 AM | #39 | ||
Typical though isn't it... while I appreciate that rc4wd releases specific parts for these kits, 25 dollars for 16 grams of aluminium does seem kind of steep Maybe I can fabricobble something up myself Edit; fabricobbling complete. Made some brackets out of 2mm styrene. Still have to clean them up and paint them, but it had the desired effect. Also had to shorten the rear driveshaft by about 7 mm. Last edited by IVIaarten; 06-30-2017 at 11:08 AM. | ||
07-08-2017, 04:39 PM | #40 |
Rock Stacker Join Date: Mar 2017 Location: Venezuela
Amazing Work...... |
IVIaarten builds a rustless TF2 LWB with LC70 - Similar Threads | ||||
Leo's workshop RC4WD TF2 LWB with LC70 | leowrc | 1.9 Scale Rigs | 10 | 08-20-2018 03:08 AM |
2mtech's TF2 LWB LC70 build | 2mtech | RC4WD Trail Finder 2 | 20 | 09-19-2017 09:40 PM |
TF2 VDJ79 (LC70) Build From Down Under! | CalebMoto | RC4WD Trail Finder 2 | 9 | 09-19-2017 11:37 AM |
My first tf2 - lwb lc70 | Fatman489 | RC4WD Trail Finder 2 | 13 | 06-17-2017 03:42 AM |
