08-05-2017, 01:25 PM | #1 |
Pebble Pounder Join Date: Jan 2008 Location: high point
| My version of the lwb tf2
Ok guys,was going to retro fit a yota body for my class 2 chassis with a 4 door body....but I've always wanted to build a new tf2(had couple used trucks but nothing new)....a lot of choices out there as far as kits go,but I dd a 04 dcsb taco so it only makes sense I build a lwb yota...right...
08-05-2017, 01:28 PM | #2 | |
Newbie Join Date: Jan 2013 Location: high point
| Re: My version of the lwb tf2 Quote:
Sent from my VS985 4G using Tapatalk | |
08-05-2017, 01:39 PM | #3 |
After researching colors,i thing yellow was the best choice, period correct and turned out just bad arsss.lol... The rock stompers are not the most popular choice of tire,but they look great and rc4wd has really stepped there game up in compounds...super soft tires...and a period correct choice,kind of big...but so are the beloved growlers,so..... Sent from my VS985 4G using Tapatalk |
08-05-2017, 01:49 PM | #4 |
There is a ton of mods for these chassis,and after building the truck by the book(minus the small helpers)I got a small trail run in..it performed as designed...but that's kind of the reason for the mods...lol... Sent from my VS985 4G using Tapatalk |
08-05-2017, 01:58 PM | #5 |
Just like most everyone else,first shot is at the frontend,g2 towers and 90mm shocks.I went with a slightly larger front shock,for the fluid capacity.this is the heaviest end of the chassis. You can see the difference in the shock shaft at ride height. Sent from my VS985 4G using Tapatalk |
08-05-2017, 02:08 PM | #6 |
At this point,was time to add in the most needed upgrades,bowhouse skid,bearing carrier and rear spring hangers.all worked as designed and will be looking for more bowhouse parts later as they are released. Sent from my VS985 4G using Tapatalk |
08-05-2017, 02:17 PM | #7 |
Well with all that done it's time to try some other mods I've only read about. First is the motor drop,this is not for anyone who can't stomach choppy up a perfectly good chassis.....but I'm not that guy so......a couple hours later... Sent from my VS985 4G using Tapatalk |
08-05-2017, 02:33 PM | #8 |
after the motor drop,i inspected the suspension travel and found my servo horn comes in contact with the pumpkin at full compression. I took the whole front axle out of the truck and found with the servo output forward and a shorter horn install was the answer.while I was in there I disassembled the axle and modified the bone cups so the axle could turn sharper and not bind up(no pics of this mod)but it worked well. With the steering worked out I moved the steering link to above the springs. After all was said and done,i have the motor dropped,over spring steering and about 45 degrees of steering... Sent from my VS985 4G using Tapatalk |
08-05-2017, 03:44 PM | #9 |
So enough of chassis mod pics....this is no shelf queen.my regular spot(dlb rc trails)is setting up for a comp next Sunday.but I have to test this truck and let the suspension settle in.only place close by is hobby park.this has a trail system for mountain bikes and hikers,oh yea scale rc trucks.....7 miles of pure tiny truck beat down... Sent from my VS985 4G using Tapatalk |
08-05-2017, 04:18 PM | #10 |
The pics really don't do this place justice.all I can think is recon g6...I covered 7.27 miles today.that's one way,complete loop.I'm going the opposite direction next time.I spent most of the time in second gear,but always watching for diff hanger rocks(a lot of those)and root clusters.one section is black diamond.just an awesome place to run scale trucks with small tires. Sent from my VS985 4G using Tapatalk |
08-05-2017, 04:34 PM | #11 |
RCC Addict Join Date: Sep 2015 Location: Southern Maine
I'm not a Toyota guy but I like this truck. You've got it set up right and the tires look great on it. I like the motor mount mod you did. Lower center of gravity is the name of the game. Love trucks on full leaf springs! Ben |
08-05-2017, 04:41 PM | #12 |
Thanks man, the truck side hills like crazy.all my other tf2 trucks have always been top heavy roll over monsters.This one is more manageable. Sent from my VS985 4G using Tapatalk |
08-05-2017, 05:02 PM | #13 |
| Re: My version of the lwb tf2 Last edited by racer; 08-05-2017 at 05:09 PM. |
10-17-2017, 07:31 PM | #14 |
Not a lot to update on this rig.......a few miles. A few comps....updated drive shafts.new tires.... Sent from my VS835 using Tapatalk |
10-17-2017, 07:50 PM | #15 |
It has seen some gates though. Sent from my VS835 using Tapatalk |
11-24-2017, 09:01 PM | #16 |
Update time.... Pitbull 1.55 90mm shocks all around -2mm hex added(narrow the width) Added rear fender wells Battery in between frame rails Leafs are setup stiff. Not a lot of flex,but really stable. Sent from my VS835 using Tapatalk |
11-24-2017, 09:10 PM | #17 |
Time for a test run Sent from my VS835 using Tapatalk |
11-24-2017, 09:29 PM | #18 |
Went out to the uwharrie ttc(tiny truck challenge,was a team event so all the dlb team was in force. Started strong through the gated trails...1 of 100 gates hit and 11 of 30 bonus gates.some of the bonus gates were c2....but there was a lot of c2 there so..... But disaster struck rite after lunch...team challanges.....completed one of 5....Bryans rig went down to a muddy motor back feeding the esc......I stripped my servo gears....... To the servos defense.....it has pulled a season of duty in my c2 truggy(12 lbs)before running no telling how many miles in the tf2... And I got it used..... I installed new gears.....savox has been good servos for me. Sent from my VS835 using Tapatalk |
01-06-2018, 03:40 PM | #19 |
Rock Crawler Join Date: Jun 2009 Location: UK
Any updates to this great looking truck?
01-06-2018, 05:45 PM | #20 |
| Re: My version of the lwb tf2 |
My version of the lwb tf2 - Similar Threads | ||||
Chevy Pickup on LWB TF2 | 1tonblazer | RC4WD Trail Finder 2 | 36 | 04-02-2019 06:13 PM |
RC4WD's NEW TF2 LWB by 1BadDollHouseJerpBuilder | 1BadJeepBruiser | RC4WD Trail Finder 2 | 59 | 03-02-2019 06:30 AM |
My first tf2 - lwb lc70 | Fatman489 | RC4WD Trail Finder 2 | 13 | 06-17-2017 03:42 AM |
TF2 LWB bed question? | High Angle Five | RC4WD Trail Finder 2 | 3 | 04-15-2017 07:30 AM |
TF2 Mojave LWB on SCX10 | Pilot_MM | Axial SCX10 II | 3 | 01-19-2017 05:18 PM |
