10-05-2017, 05:20 PM | #41 |
| Re: GreatScott's TF2 Reboot Not sure yet. I will be installing a roll bar when the body gets back, just need some way to mount the 2000mha 2S packs so they will stay put, and not look like batteries.
11-10-2017, 08:43 PM | #42 |
So, been getting projects to a point of completion so that I can get them off of the bench, and finally coming around to the TF2. The body still seems too short, of the chassis still too long, but I am making it work. There is a reason why I don't throw anything away, you never know when it will come in handy. I wanted to mount to my winch anchor, and was about to fab up a mount out of aluminum when I spotted a spare chassis brace from my Kind Hauler kit... I cut it in half, cleaned it up, and put a hook on there for the tow rope... Untitled by GreatScott, on Flickr by GreatScott, on Flickr To remove it I just pull the body clip. |
01-20-2018, 11:20 AM | #43 |
Finally bit the bullet and did the drop motor mod. The mod is pretty easy to do. The biggest tip I have for this mod is to gut everything off of the chassis forward of the transmission, make all of the cuts needed, install the motor, then put everything back. Also, mount the servo from the bottom, otherwise you'll need a spacer to get the steering link around the motor. RC4 WD TF2 Motor drop mod by Scott O, on Flickr RC4 WD TF2 Motor drop mod by Scott O, on Flickr |
03-29-2018, 06:48 AM | #44 |
Had this truck out for its C1 debut, and it was lackluster at best. The truck really did not do all that bad and the motor drop and suspension mods helped a lot. One of the biggest problems is steering, which simply sucks in stock form. After a good deal of research, it looks like tweaks and mods for the stock front axle are hokie, at best and tend to cause more problems than they solve. It seems like the only tried and true way to get any kind of steering out of this truck is to replace the axles all together. As for the rest of the truck, it seemed to hold up pretty well, I had a screw come out when I was on the first course, but that was my fault, no lock-tite. I am still on the fence about this rig, it looks great and hard to beat for scale points, but my C1 SCX10 drives circles around it. |
03-29-2018, 12:52 PM | #45 |
Quarry Creeper Join Date: Aug 2017 Location: Satan's Armpit
It's "horror" stories like yours that make me hesitant to pick up a RC4WD kit. That and the parts always seem to be out of stock and backordered... They look like fun, and maybe I'll try a kit one day. |
03-29-2018, 05:35 PM | #46 | |
Rock Crawler Join Date: Apr 2017 Location: US
| Re: GreatScott's TF2 Reboot Quote:
Guess if your that disappointed you can always sell it and move on. If you weren't running it in comps would you think different about it? How much of trail time have you put in this truck, just curious? | |
03-29-2018, 06:38 PM | #47 |
RCC Addict Join Date: Nov 2016 Location: 1972 born Christian, Chinese.
Definitely what a good read in this evening. |
03-30-2018, 06:57 AM | #48 | |
| Re: GreatScott's TF2 Reboot Thanks!!! Quote:
I built it specifically for C1 comps, so without comps in mind I would not have one at all. It is VERY hard to beat the scale points this platform gives right out of the box, but for everything it gives to scale points it takes away from in performance. And, to be fair, my SCX10 I am comparing this to does have the XR mod, along with a few more tweaks that make it a great comp rig. Right now I am trying to decide if I want to sell it and get a Bomber, I am currently lacking a C3 rig. I am just not sure what to ask for it. | |
03-30-2018, 11:43 PM | #49 | |
So what bomber you looking at rtr or kit? | |
04-01-2018, 08:20 AM | #50 | |
05-21-2018, 04:11 PM | #51 |
Newbie Join Date: Sep 2017 Location: Austin
Greatscott - great read as i'm on the fence about purchasing the tf2 kit. I'd mainly use the tf2 on hiking trails, no competition but occasional water crossings and some rock crawling are involved. I currently have a TRX-4 and its been fantastic out of the box (i only had to replace the steering servo horn). I've also followed your TRX-4 thread - how would you compare the TRX-4 to the TF2 for use on hiking trails? I know the TRX-4 has the tf2 beat on ground clearance but is the tf2 up to the task with minor mods? |
06-20-2018, 05:17 PM | #52 |
Any pictures of this showing your steering setup and clearances after the motor drop? How low the motor sits, any clearance issues with the front axle?
06-25-2018, 12:26 PM | #53 | |
Sorry guys, didn't see that you had asked questions. I sold this truck a bit ago, so I don't wonder through very often. Quote:
Sorry, no pictures. I think I had to put in a 5mm spacer on the servo horn and recenter the servo, other than that there were no issues with the motor drop. | |
06-25-2018, 01:18 PM | #54 |
OK, thanks for your reply. |
06-26-2018, 06:22 AM | #55 | |
Rock Stacker Join Date: May 2018 Location: US
Sent from my LGLS991 using Tapatalk | |
06-26-2018, 06:40 AM | #56 |
| Re: GreatScott's TF2 Reboot Without having a trick like this putting those wheels together is like herding cats.
06-26-2018, 06:42 AM | #57 |
| Re: GreatScott's TF2 Reboot |
06-26-2018, 10:53 AM | #58 |
06-27-2018, 05:26 AM | #59 |
07-03-2018, 09:11 PM | #60 | |
Rock Crawler Join Date: Sep 2013 Location: New Orleans
GreatScott's TF2 Reboot - Similar Threads | ||||
Dan's Hilux reboot/2.0 | Sugarfree85 | RC4WD Trail Finder 2 | 0 | 01-21-2017 12:31 PM |
Greatscott's M2 XR-10 | Greatscott | Axial XR10 | 94 | 01-27-2015 11:55 AM |
reboot of my black dog and the start of a micro rig | slim_chance | General Scale Talk | 0 | 11-25-2012 12:27 AM |
Greatscott's SWX (Finished at last!!!) | Greatscott | Axial AX-10 Scorpion | 7 | 03-08-2010 11:02 PM |
