10-07-2017, 11:01 AM | #1 |
Rock Stacker Join Date: Sep 2016 Location: Frisco
| EMU vs Superlift
Are the Old Man EMU's and the Superlift's basically the same shock, just different color and label? I am going the route of internal spring removed 90mm front with Geoland loop and either 90 or 100mm in the rear on my TF2 regular cab. Is there a reason to pick 100 over the 90mm for the rear? I have not started the build, it is still in the box so just planning. I do see where the EMU's don't come in a 100mm, just the Superlift's... Thanks, Last edited by GR8 PMKN; 10-07-2017 at 11:05 AM. Reason: Adding explanation |
10-09-2017, 02:17 AM | #2 |
I wanna be Dave Join Date: Apr 2014 Location: North Carolina
| Re: EMU vs Superlift
The Emus and Superlifts are basically the same except for color/graphics and available sizes. As for rear shocks, there's no reason to use 100s in the back. You won't get any extra usable travel out of it, so 90mm is fine. Good luck with your build!
10-09-2017, 07:53 AM | #3 |
Thank you. I was hoping you would reply. I have been following your advise on JatoTheRipper's build. I need to finish my SCX10-2 build before I start this one or neither one will ever get finished.
EMU vs Superlift - Similar Threads | ||||
emu´s seriesIII lookalike | emu | 1.9 Scale Rigs | 11 | 03-02-2016 03:12 AM |
Old Man Emu shocks | B94Cast | General Scale Talk | 9 | 10-16-2013 07:33 PM |
New old man emu shocks | adamargue | General Crawlers | 5 | 09-13-2013 06:04 AM |
