10-20-2017, 01:51 PM | #1 |
Newbie Join Date: Jan 2005 Location: Metro Detroit
| TF2 RC4WD Topper Mounting Ideas
Hi all, I have a RC4WD topper that I am installing on my TF2. Or at least, I was installing it when the long mounting rails cracked and failed at the mounting boss locations. I had used some Velcro on the inside of the bed rails and inside of the mounting rails. I had installed the topper and wanted to adjust it, so I started to remove the topper when the rails failed. I have contacted RC4WD to see if they have any replacement rails available, but I am thinking that they do not. The rails were very loose inside of the bed, which is why I went with some Velcro. Also, I wanted it removable. In lieu of the plastic rails, I am thinking that I can come up with a replacement system that will be a little more robust to removal/replacement. My goal is to have the topper secure but non-permanent. I have looked around and while there are many images of the topper on the trucks, I cannot find anything for mounting it to the truck. If anyone has undertaken a new/replacement/updated mounting for a bed topper, I would appreciate your input. Thanks, Tim in Michigan |
10-20-2017, 11:17 PM | #2 |
Quarry Creeper Join Date: Nov 2015 Location: Walkerton
| Re: TF2 RC4WD Topper Mounting Ideas
I've seen other use rare earth magnets to hold the body on the chassis. I just purchased some to use to hold the body on my build. Maybe there's a way to use them to hold the topper on. I heard they have a strong hold. Sent from my VS995 using Tapatalk |
10-23-2017, 07:43 PM | #3 | |
| Re: TF2 RC4WD Topper Mounting Ideas Quote:
More to come. | |
10-25-2017, 10:42 AM | #4 |
Brief update, RC4WD does not have any toppers in stock to rob the rails from, so I am going it alone. I glued the broken bits back into one, less than stable piece. I will use this as a basis/template for what ever I come up with. I think my local hobby shop has some angle plastic that I may try and use. Once I come up with a plan I will provide an update.
10-28-2017, 04:42 AM | #5 |
RCC Addict Join Date: Feb 2005 Location: Guam
My topper came in witingh one mounting rail broken. Haven't tried to glue it back yet. I'm gonna try using magnets to mounting n removing. I'll post here when I finally get to mounting mine.
10-28-2017, 03:19 PM | #6 |
| Re: TF2 RC4WD Topper Mounting Ideas Interesting. I was leaning towards some magnets as well. I will definitely be interested in what you come up with. I am heading to the hobby shop tomorrow to pick up some magnets, various rails, and anything else that I think I can use. Thanks for the info.
01-27-2018, 05:23 PM | #7 |
Quarry Creeper Join Date: Dec 2016 Location: DA U.P.
How did the magnet idea work out for you?
TF2 RC4WD Topper Mounting Ideas - Similar Threads | ||||
Rc4wd tf2 topper question | lawndog | RC4WD Trail Finder 2 | 2 | 03-19-2016 09:15 PM |
