Thread: A&M Garage High Clearance Skid
Old 08-06-2019, 10:12 AM   #1
Default A&M Garage High Clearance Skid
Does anyone know if this will work with the R4 and Hammer T-case or the GCM LRT2 scale drivetrain?
If not, if anyone that has this skid plate, would you measure and tell me how deep (from the frame rail to the inside bottom of the plate) it is?
TIA
Ironhide13 is offline   Reply With Quote
Old 08-08-2019, 11:30 PM   #2
Default Re: A&M Garage High Clearance Skid
You're in luck, sorta. I have the parts, but don't own a truck for them yet. Best I can do is measure. Please let me know what you find out as I probably should have done this research myself before purchasing the parts.
thispiece is offline   Reply With Quote
Old 08-11-2019, 02:44 PM   #3
Thanks!
I did get an answer from A&M Garage. They said it won't clear out of the box, but you could still use it. Others have made it work by using a spacer of sorts to create the clearance needed. So maybe some styrene strips cut to fit?
A&M Garage High Clearance Skid - Similar Threads
High clearance skid plates BrokeBob Vaterra Ascender 4 09-02-2018 05:52 PM
High clearance skid Desmo Vaterra Ascender 9 04-19-2017 01:29 PM
High clearance skid made easy! Reaxion911 G-Made Sawback 5 01-02-2014 06:52 PM
