Thread: Bruiser mod and o-ring mod
Old 03-02-2018, 07:46 AM   #1
Default Bruiser mod and o-ring mod
Is it advisable to do both these mods, or is that just asking for trouble? I have the parts to do both, but before I do I figured I should ask.
Thanks
GR8 PMKN is offline   Reply With Quote
Old 03-02-2018, 02:43 PM   #2
Default Re: Bruiser mod and o-ring mod
Just do the oring mod i run all 3 springs in the rear with 90mm shocks
and it flexes nice and scale almost the same as with revolver shackles
afrofroggy is offline   Reply With Quote
Old 03-02-2018, 05:06 PM   #3
Well I just bought the bruiser shackles and front hangers off of RPP. I have the o rings as well. Wanted the more true look to the front end.
Old 03-02-2018, 08:28 PM   #4
The problem you'll find with the o-ring mod in the front is that it creates significant steering slop. I tried it and ended going with the chino mod and prefer that. Just my 2 cents
Digital is offline   Reply With Quote
Old 04-02-2018, 01:49 PM   #5
What size o-rings did you use?
ProjektONE is offline   Reply With Quote
Old 04-06-2018, 02:12 PM   #6
I ended up using 2.5mm x 1.5mm o-rings from Axial. Part # AXA1179
Bruiser mod and o-ring mod - Similar Threads
Do you prefer the Chino mod over the O-Ring mod or vice-versa? Digital RC4WD Trail Finder 2 1 01-18-2018 02:22 PM
part number help for the O-ring mod hellacool Team Losi Comp Crawler 7 03-11-2010 02:57 PM
write up,for mod for putting ring and pion from a e savage in wheely king thevulgarcowboy HPI Wheely King 35 06-26-2009 09:20 PM
o ring mod leon Duratrax Cliff Climber 4 04-12-2009 05:55 PM
