06-29-2018, 07:37 AM | #1 |
Rock Stacker Join Date: May 2018 Location: US
| Helical cut gears
Are they worth the money or should i just replace it with the straight cut deals the straights are 30 and the helical cut are 70 Sent from my LGLS991 using Tapatalk |
06-29-2018, 07:39 AM | #2 |
| Re: Helical cut gears
Blown Sent from my LGLS991 using Tapatalk |
06-29-2018, 10:11 AM | #3 |
Did you read the stickies and shim the diffs as directed? I've read that the helicals (properly shimmed of course) are more durable than the straight cut standard gears. I'd give the helical gearset a try. |
07-01-2018, 08:50 PM | #4 |
Newbie Join Date: Jun 2018 Location: Monroe
Most people think that straight cut (actually called spur) gears are stronger than helical gears and that’s why their used. While generally race transmissions with straight gears are very strong, its not because of the straight teeth on the gears. What may shock you is that straight cut gears are actually weaker than a same sized helical gear. The reason for this is quite simple: helical gears have more teeth meshing and thus have a greater load bearing surface area. Another myth is that straight cut gears are more efficient than a helical gears; but the difference in efficiency is negligible with both spur and helical gears having about 98-99% efficiency. So why are straight cut gears used in race transmissions? Well, there is only one real reason, and that is because straight gears don’t produce any axial loads (thrust loads). Its very easy to build strong gears that are either straight cut or helical, so that’s not the problem. The problem is when you start putting a lot of torque through helical gears, the axial loads become so high that you need a very strong transmission case and shafts (axles) to contain the loads; this can add significant weight to the transmission. Straight cut gears simplifies the transmission case design and also the types of bearings used. This allows for a very light weight transmission to be designed – and we know that weight is everything in a race car. The one negative of straight cut gears, and its a big one, is that they produce a lot of noise. |
07-01-2018, 09:24 PM | #5 | |
| Re: Helical cut gears Quote:
Sent from my LGLS991 using Tapatalk | |
07-01-2018, 09:50 PM | #6 |
Rock Crawler Join Date: Jun 2018 Location: Orange County, CA
Did you get the fancy gears? Sent from my iPhone using Tapatalk |
07-01-2018, 11:17 PM | #7 |
| Re: Helical cut gears |
07-02-2018, 09:52 AM | #8 |
Newbie Join Date: Apr 2018 Location: Hamilton, NJ
My diffs in my tf2 lwb r shot..I shimmed them and they work just find..luckily i have a set as spare. Sent from my LG-TP450 using Tapatalk |
07-03-2018, 05:45 AM | #9 | |
07-03-2018, 06:38 AM | #10 | |
RCC Addict Join Date: May 2015 Location: Price Twp.
That is the nature of helical cut gears. The have more contact area at any given moment, with more individual gears involve, and thus prove more strength. | |
Helical cut gears - Similar Threads | ||||
Helical gears for TF2 | tokdl | RC4WD Trail Finder 2 | 5 | 09-17-2014 10:47 PM |
helical gears | bigdog2 | Kyosho Crawlers | 6 | 07-11-2009 11:24 AM |
