07-06-2018, 08:35 AM | #1 |
Rock Stacker Join Date: May 2018 Location: US
| Best way to remove the half cab back to install full cab back
I am going to build a flat bed on my hilux. And am Looking for the cleanest way to pull the half cab back out so i can install the full cab back suggestions please Sent from my LGLS991 using Tapatalk |
07-06-2018, 09:53 AM | #2 |
Pebble Pounder Join Date: Sep 2012 Location: Clarksville
| Re: Best way to remove the half cab back to install full cab back
I have been thinking about doing that myself. But if you really glued the half cab panel in like I did,it may be a chore. Since I used plastic weld and shoe goo,I would almost have to use my dremel and slowly go at it without damaging the cab. If you used only one glue and didn't really weld the plastic,you may be able to use a hobby knife and cut it loose. Disclaimer: I'm not responsible for any cuts by using a hobby knife or sharp cutting tools as I'm only giving some ideas.
07-06-2018, 09:55 AM | #3 | |
| Re: Best way to remove the half cab back to install full cab back Quote:
Sent from my LGLS991 using Tapatalk | |
07-06-2018, 10:07 AM | #4 |
Dunno, was considering doing same on mine, but it's glued in from the factory. Wish I had a good suggestion for this.
07-06-2018, 10:09 AM | #5 |
The heat gun and acetone will more than likely melt the plastic. I would go another route if it was me. Chances are the cab back half panel isn't adhered that well,but I'm taking a guess because I put my cab together.
07-06-2018, 10:10 AM | #6 |
I think iam gonna boil it like you do with tires and rims Sent from my LGLS991 using Tapatalk |
07-06-2018, 10:12 AM | #7 |
Keep us updated
07-06-2018, 10:13 AM | #8 |
| Re: Best way to remove the half cab back to install full cab back |
07-06-2018, 07:53 PM | #9 |
Newbie Join Date: Apr 2013 Location: Drumright
You can use thread or a very fine line to precisely cut the plastic. Just go slow, sand to a straight finish. Leave yourself a little wiggle room for finish sanding though. Sent from my iPhone using Tapatalk |
07-07-2018, 07:31 AM | #10 | |
07-07-2018, 09:02 PM | #11 |
Rock Stacker Join Date: Aug 2016 Location: S.E. Wi.
I also considered doing this, but instead of removing the half back I would cut the full back and use just the lower section, glue it and finish the seam.
07-07-2018, 11:36 PM | #12 | |
Best way to remove the half cab back to install full cab back - Similar Threads | ||||
Proline Back-Half Cage for Pro-Line Cab Only Crawler Bodies | durok | Paint and Body | 17 | 06-27-2018 09:12 PM |
