Thread: Anybody know if this upgrade works?
Old 10-02-2018, 01:45 PM   #1
Default Anybody know if this upgrade works?
Hello my friends. I want to upgraded the axles in my gelande 2. Has anyone used or know that the scx10 2 axles will work? The quicker the reply, the better.
Thanks friends.
Ilovecrawling12 is offline   Reply With Quote
Old 10-03-2018, 05:09 AM   #2
Default Re: Anybody know if this upgrade works?
They are wider than your stock axles. I use the ascender axles. You can narrow them by 8mm on each side. very simple mod .
mudbeast2 is offline   Reply With Quote
Old 10-03-2018, 07:20 AM   #3
I wasn't sure about the width of the AR44's (SCX10 2 axles) vs. Yota I/II (Gelande 2), so I didn't want to answer you right away.
Do keep in mind the differences in final drive ratios compared between the 3 main ones:
Gelande/TF2 (Yota / K44): 32T/12T = 2.67
SCX10 2 (AR44): 30T/8T = 3.75
Ascender: 24T/13T = 1.85
In short, the AR44s will give you lower gearing compared to the stock Gelande's, and the Ascender's will give you higher gearing. The differences can be made up with a different pinion on the motor. Hope that helps.
Ironhide13 is offline   Reply With Quote
Old 10-04-2018, 05:03 AM   #4
You are correct, When I use Ascender axles in my Gelande I have to use a 10 or 9 tooth pinion gear. But it does balance out.
Anybody know if this upgrade works? - Similar Threads
If it works ?? Frank211 Chit Chat 6 06-04-2018 09:31 AM
Is this how it works?? SkiSteve Electronics 8 02-20-2017 01:42 AM
Another TH in the works Hobine Vaterra Twin Hammers 19 12-30-2016 08:52 PM
something in the works fletch 1.9 Scale Rigs 20 05-27-2010 11:17 PM
Something new in the works! aubie Chit Chat 73 05-26-2005 12:40 PM
