![]() | #61 |
Go Buckeyes! ![]() Join Date: Jun 2017 Location: Mid-Ohio
![]() | #62 | |
Quarry Creeper Join Date: Dec 2014 Location: Tulsa
| ![]() Quote:
thanks | |
![]() | #63 | |
| ![]() Quote:
![]() I actually bought both versions, the standard reversal kit and the bumper with the +4mm. If you go back and look at post #14, it shows the TF2 Shackle Reversal Kit without the +4mm. This kit is just the plates to reverse the shackle mounts. On post #48, I installed the TF2 High Clearance Bumper/Shackle Reversal with the +4mm. When I purchased this, I wanted to try out the +4mm to see how I liked it. I think the +4mm is the better option. Both posts, #14 & #48 show a side view showing where the front of the leaf is mounted. Here are a couple pics I just took to show the bumper with the +4mm. ![]() ![]() Hope this helps you! Let me know if you need more pics. | |
![]() | #64 |
That was a ton of help! Thanks alot. I clocked the motor down, and I don't see that interfering with the axle moved forward. Not anymore than it already is. Lol |
![]() | #65 | |
| ![]() Quote:
![]() Clocking the motor is still on my list of "to do's". I just wasn't sure how it would interfere with the axle and steering linkages. As mine sits now, spacing the steering servo up really helped out with the clearance between the axle and servo. I hate to mess that up, but getting the motor down lower would definitely help out the performance. | |
![]() | #66 |
Quarry Creeper Join Date: Aug 2014 Location: Chilliwack
Hey B-MOW, Do you happen to have any photos of how you installed the servo winch/ran the line? I'm getting my Marling ready for class 1, I figure I can mount the servo winch where the shift servo would go but have no idea how to run the winch line to the front bumper. |
![]() | #67 | |
| ![]() Quote:
Here is a pic of my SCX10.2 that I ran the winch line thru brake line. I'll do something like this on my Marlin. I used Traxxas rod ends with the balls removed slid over the brake line to use as mounting points. ![]() Not sure how soon I'll get to mounting the servo winch, but when I do I'll post up pics. | |
Mike's RC4WD Marlin Crawler TF2 | 1BadJeepBruiser | RC4WD Trail Finder 2 | 21 | 08-26-2019 03:06 PM |
Tf2 kit or marlin crawler | treadway47025 | RC4WD Trail Finder 2 | 8 | 03-25-2018 02:04 PM |
