Over/under transfer case???? Looking for thoughts and opinions for the RC4wd over/under transfer case. I’m considering one for a Frankenstein build I’m doing. Will be using parts from VS4-10, axial and Rc4wd. I’ve used the hammer T-Case before but have no experience with the over/under. Just wondering about quality and reliability. Sent from my iPhone using Tapatalk |
Re: Over/under transfer case???? Quote:
Re: Over/under transfer case???? I've been also considering it for my G2, but as you know, it needs 2 parts, the mount with the battery tray and the transfer case itself, which cost more than 120 pounds altogether. Its half the price of a brand new Enduro kit....Thats abusive. |
Re: Over/under transfer case???? 3 Attachment(s) Now this won't work in all applications & certainly isn't a drop in to a RC4WD truck but for custom building where you're dealing with a DIY cross member you can achieve the exact same OD from a stock RC4WD T/case without paying the extra for their OD version, just got to turn it over & re-arrange where you drive in & where you attache the drive shafts. Stock in top pic Alternative in lower Saw someone else do it & it worked out well in my TF2 Blazer, turns the AtlasII T/case right way up for starters & swaps front drvie shaft off to the right drop to suit the K44 axle |
https://store.rc4wd.com/RC4WD-OverUn...se_p_7141.html RC4WD OVER/UNDER DRIVE TRANSFER CASE Part Number:Z-U0039 Specifications: 1.47 / 1 Gearing .8 Mod Gears Hardened Steel Gears Cast Casing Wide Gears Has same mounting as our popular Hammer Transfer Case Output Shaft OD: 0.19in / 5.0mm Total Weight: 6.21oz / 176g What's Included: 1x RC4WD Over/Under Drive Transfer Case 1x 16T Gear 1x 17T Gear 1x 19T Gear 1x 20T Gear 1x M3 x 6mm Steel Button Head Cap Screws (Black) 1x M3 x 10mm Steel Button Head Cap Screws (Black) There are 6 gearing options available: 15T/22T (Stock) : 1 : 1.47 Gear Ratio - Front axle goes same speed as rear To change the gear ratio remove the cover on the side with the two shafts. The following are the gear combinations of Rear Output to Front Output: 17T / 19T combo = 1:1.27 front axle will rotate 27% faster than rear 16T / 20T combo = 1:1.33 front axle will rotate 33% faster than rear 19T / 17T combo = 1:1.42 front axle will rotate 42% faster than rear 20T / 17T combo = 1:1.57 front axle will rotate 57% faster than rear 20T / 16T combo = 1:1.67 front axle will rotate 67% faster than rear |
Re: Over/under transfer case???? I bought the RC4WD OD/UD transfer case, just need to go through it and then install to my TF2. Going with the 17T / 19T combo for 27%. :) |
Re: Over/under transfer case???? You've got me having second thoughts now about my OD ratio, somehow when I calc'd it before it didn't seem that high compared to say OD/UD in an scx10 but looking again 47%OD is quite a bit & is quite different to the Axial ratios 28% OD/UD (13% UD/STD or 13.6% STD/OD for those playing at home) |
