07-14-2019, 09:29 AM | #1 |
Newbie Join Date: Jan 2019 Location: Longmont
| RC4WD Underdrive/overdrive transfer case
Is anyone out there running the U/O transfer case? Not the transfer case mod but the actual transfer case with U/O? I am currently running the AM garage skid/transfer with the stock transfer case and it works well. I have been curious of running OD but have not been able to get the mod to work, to much binding and my electronics and motor and running really hot like 190-200degrees plus the binding makes the truck run jerky., I am pretty sure it will not work with the AM garage skid and transfer case flip. Just curious what folks experience with the U/O transfer case? Sent from my iPhone using Tapatalk |
07-31-2019, 11:10 AM | #2 | |
| Re: RC4WD Underdrive/overdrive transfer case Quote:
https://store.rc4wd.com/RC4WD-OverUn...se_p_7141.html swapping around the stock Hammer tcase to OD the front axle is waaaay too much overdrive imo and will bind badly and could cause problems like you're having as well as premature axle, transmission, tcase failures. | |
08-31-2019, 11:14 PM | #3 | |
I bought one as well and it it pretty freaking good. I swapped out the AM skid for a bowhaus high clearance skid and it is working super well, just clocked the motor too and man, my tf2 is a shredder. Sent from my iPhone using Tapatalk | |
09-05-2019, 11:55 AM | #4 |
Newbie Join Date: Jan 2012 Location: waynesburg
Best mod yet
12-26-2019, 10:08 AM | #5 |
Quarry Creeper Join Date: Nov 2008 Location: Cincinnati
Any additional comments on this? Which gearing options are you using? How much front overdrive is too much? Sent from my SM-N975U using Tapatalk |
01-13-2020, 04:28 AM | #6 |
Newbie Join Date: Apr 2017 Location: South Africa
Yip been running the OE overdrive tranny in my marlin a few months on 24% and it seems to hold up well, I have to say this is not a trail rig and I almost only comp with it. I do not think it will cope with 24% on the trails but 6% or 12% yes absolutely.
01-24-2020, 06:33 PM | #7 |
I'd recommend about 10-12% more than that affects longevity of parts and does not drive 'naturally' so to speak. |
03-07-2021, 05:26 PM | #8 |
Quarry Creeper Join Date: Feb 2008 Location: Quincy
Thanks much for the info on this. Was looking into getting this t-case but wasn't sure, this little thread cleared up all my questions. Thanks again |
09-06-2021, 01:42 AM | #9 | |
Newbie Join Date: Jun 2020 Location: Choctaw
Looking at this on RC4WD's listing for this t-case, I don't see a combo for anything less than 27% OD. I think that's a bit much for a non-comp committed rig. I like to run somewhere between 18 and 20%. Do I understand your post correctly that there are other gearing options (besides the ones RC4WD lists) that can be used with this transfer case to get you less than 20% OD? | |
09-06-2021, 02:24 AM | #10 | |
09-06-2021, 11:43 AM | #11 | |
Nice! That might be the way to go then. Either that or an axle swap, one of the two. Thank You! | |
09-06-2021, 03:29 PM | #12 |
| Re: RC4WD Underdrive/overdrive transfer case |
09-06-2021, 11:57 PM | #13 |
09-06-2021, 11:57 PM | #14 |
RC4WD Underdrive/overdrive transfer case - Similar Threads | ||||
overdrive transfer case | intheworks | Axial SCX10 II | 27 | 08-01-2018 02:51 PM |
