10-22-2019, 02:21 AM | #1 |
I wanna be Dave Join Date: Sep 2019 Location: US
| TF2 Transmission: R3 2-speed vs R3 single-speed vs R4 single-speed
Two things...first, still a crawler newb (Axial Capra, my 1st crawler) is almost finished); second, just ordered the TF2 w/ Mojave 2dr kit (yea, I know I said the VS4-10 would be me second crawler, but they're out-of-stock, plus I can't afford it right now, so it'll be my 3rd). Ok...enough of that. Anyway......... As I understand it, the kit comes with the 2-speed version of the R3 tranny. I don't know if the R4 is a "newer" tranny, or just a more 'robust' one. Also, as far as I've been able to determine, there is no 2-speed version of the R4. Also, since I can't seem to find any detailed info on these transmissions, some info from "those in the know" would be greatly appreciated. As for my questions, I'll break then down as simple as possible: 1) Is the R4 better than the R3, or the other way around? 2) If there's no 2-speed version of the R4, does anyone know why? Since I'm building this vehicle for 'scale detail', I'd REALLY like to mount an engine, but there's a "problem". The only "engine" I've been able to find for the 2-speed R3 (Z-S1749) is not only too "basic" (you can't add belts, pullys, houses, etc), it's also the wrong type of engine (ie. 'modern'), and it's not even a full "engine" (essentially, it's just the head & valve covers). This "situation" leads to additional questions: a) If the 2-speed R3 is better than the other two, are there other "engines" available...p preferably something that not only more accurately resembles a full engine, but one that is also reminiscent of the correct time period? b) If the 2-speed R3 is the 'worst' of the three, which of the other two is best (and why)? This newb could use all the help he can get right now. Thanks, in advance, for any/all helpful info provided. ~ More peace, love, laughter, & kindness would make the world a MUCH better place |
10-22-2019, 10:32 AM | #2 |
I wanna be Dave Join Date: Jan 2006 Location: Corruptifornia
| Re: TF2 Transmission: R3 2-speed vs R3 single-speed vs R4 single-speed
R2 is old OG noisy rectangular box of a transmission....pass. R3 single speed is compact kinda scale-ish and has held up well ime. R3 single speed is what I've been running in my TF2. R3 two-speed is little bigger kinda scale-ish and from what I"ve read been pretty strong and reliable. R4 is only available in single speed and no 2-speed available gear setup as per RC4WD but I've not used it. |
10-24-2019, 04:28 PM | #3 |
Ok...so, the R4 is single-speed only. I get that. What I'm really interested in is the comparison between the R3 (2-speed) & R4, in terms of quality, "bulletproof-ness", overall strength, gearing, etc. As I'm starting to learn/understand, some crawler transmissions are geared (physically, and metaphorically) towards serious low-speed "rock crawling", others towards "trail runs", others towards "rock racing", and so forth. Some are geared in such a way that they can be used under more than one category (ie. they sorta-kinda fall 'in-between' categories). I guess part of what I'm asking is, which does the R3 2-speed fall under, which does the R4 fall under...and, in regards to both, is one "better" (in build quality, materiel quality, long-term functionality, etc) than the other. While half of me likes the idea of having a 2-speed tranny, the other half doesn't see the realistic need for it. Additionally, I don't know (for either tranny) if a DIG is possible...but, if it is, to me, that might give that tranny an "advantage" over the other. I've searched on the last point, and, so far, I've turned up nothing, so I'm assuming DIG isn't a possibility with either transmission, which only takes us back to the original points, as mentioned above. ~ More peace, love, laughter, & kindness would make the world a MUCH better place |
10-24-2019, 04:52 PM | #4 |
I wanna be Dave Join Date: Jun 2017 Location: Humboldt county
There are tons of 3D printed options for engines, have a look at what Shapeways has https://www.shapeways.com/marketplac...q=engine+cover I know there are a few different versions of 22R's out there, though its worth noting not all are meant to slide over a motor so look out for that. |
10-24-2019, 04:59 PM | #5 | |
| Re: TF2 Transmission: R3 2-speed vs R3 single-speed vs R4 single-speed Quote:
~ More peace, love, laughter, & kindness would make the world a MUCH better place | |
10-24-2019, 05:30 PM | #6 | |
10-24-2019, 05:49 PM | #7 | |
However, what I'm far more interested in is overall quality, as well as purpose, of the transmission, as mentioned in my previous post. The RC4WD "engine" for the R4 could prove to be most realistic looking, but if the transmission is only half as good as the R3, then why would I want it? On the other hand, if the R4 is the better transmission, then I'm wondering if there are other, more realistic looking, "engines x than the RC4WD offering. Put another way, although the engine is somewhat important, the transmission is somewhat more important. Sorry if I confused anyone...does it make more sense when worded this way? ~ More peace, love, laughter, & kindness would make the world a MUCH better place Last edited by Panther6834; 10-24-2019 at 06:05 PM. | |
10-24-2019, 08:01 PM | #8 | |
I wanna be Dave Join Date: Jan 2005 Location: Raleigh-ish vicinity
I have a TF2 that started as a 2 speed, was swapped to a R4, and now runs a R3 single speed so I have a little insight. Answers below in red. Quote:
10-24-2019, 08:16 PM | #9 | |
Seriously, though, thank you for not only the info on the R3 & R4 , but also the LRT2, and the "Scale Designs by MrcommanD" info. ~ More peace, love, laughter & kindness would make the world a better place Last edited by Panther6834; 10-24-2019 at 08:18 PM. | |
11-05-2019, 12:40 PM | #10 | |
~ More peace, love, laughter & kindness would make the world a MUCH better place | |
TF2 Transmission: R3 2-speed vs R3 single-speed vs R4 single-speed - Similar Threads | ||||
Turning 2 speed trans into single speed | Betts818 | General Crawlers | 2 | 06-20-2016 12:52 PM |
F350 3 speed to single speed conversion, tips/ideas needed please | neo | 1.9 Scale Rigs | 10 | 02-11-2010 02:49 PM |
