10-27-2019, 05:13 PM | #1 |
RCC Addict Join Date: Feb 2008 Location: your back yard
| Drive Shafts
I'm looking for shafts to upgrade to once I start building my kit with the A&M skid. I know the front stock is to short but I cant find info on what length is needed. TIA |
10-27-2019, 06:57 PM | #2 |
| Re: Drive Shafts
I’m running the SuperShafty MIP HD shafts. They are designed for the TF2 with the A&M skid. Sent from my iPad using Tapatalk |
10-27-2019, 07:02 PM | #3 |
I wanna be Dave Join Date: Sep 2019 Location: US
| Re: Drive Shafts
I would venture to say that the Vanquish Incision driveshafts would also work. A few people (myself, included) have installed the shafts intended for the SCX10/SCX10.2 onto the Axial Capra, and they fit, no problem. If course, this might depend on which TF2 chassis you have - standard, SWB, or LWB. ~ More peace, love, laughter & kindness would make the world a MUCH better place |
10-28-2019, 05:20 AM | #4 |
| Re: Drive Shafts
The super shafty are out of stock so I was looking for other option but since I dont know how long till I build it's making things challenging. Thought about just doing stock scx10.2 but looking at $55 just for plastic. |
10-28-2019, 06:10 AM | #5 |
| Re: Drive Shafts
Just noticed that Tapatalk blew up my pics! Sorry about that! I am not sure what the length of the front driveshaft is, but I do have to say that the Incision driveshafts are very nice. I have them on my VP VS4-10 Origin and Pro. They are built very well and after a year of abuse, there is very little play in them and the pins are still tight. |
10-28-2019, 07:25 AM | #6 |
| Re: Drive Shafts
I used the 95-130mm Junfac shafts on my TF2 (before they actually sold the TF2 driveshaft set) they have held up with no problems and have a diameter that is rather scale. If you can find shafts that list the max and min lengths, anything in the same 95-130mm range should work. The cheap option for a much stronger driveshaft is to buy a set of Axial Wild Boar HD takeoffs on ebay for $20ish. Then you can mix and match ends and center sections or cut them down to get the length you need. Either way, you will likely have to shorten the outputs on the t-case and axle pinion to use anything other than RC4WD shafts. The outputs are usually a little too long and the holes for the screw pins won't line up with the driveshaft holes. |
10-28-2019, 05:48 PM | #7 | |
| Re: Drive Shafts Quote:
I'll look into the outputs and get them trimmed up. Thanks for the feed back guys, very helpful! | |
10-28-2019, 05:54 PM | #8 | |
Thanks for the help.. | |
10-29-2019, 01:45 PM | #9 | |||
https://www.vanquishproducts.com/inc...0-2-rtr-scx10/ Quote:
Drive Shafts - Similar Threads | ||||
AX10 MIP C Drive dig drive shafts in stock! | RPP Hobby | RPP Hobby | 1 | 12-03-2009 10:50 PM |
