Thread: STHA Toyota HiLux
Old 03-21-2020, 01:20 PM   #41
Default Re: STHA Toyota HiLux
I modified my RC4WD trail finder 2 suspensions, now I get a nice flex.
Harder in front, so it doesn’t dive in holes but float above and super smooth in the back to move freely. Works as planned!
https://stha.home.blog/
STHA videos
STHA is offline   Reply With Quote
Old 03-23-2020, 12:39 PM   #42
We worked on a new trail section.
Testing time!
STHA videos
Old 03-23-2020, 02:53 PM   #43
Moderator
JatoTheRipper's Avatar
For some reason you had this posted in both the 1.55 and TF2 sections. A thread should only be in one section so I merged them. I'm in the process of deleting the duplicate posts that are a result of the merge.
Old 07-17-2020, 09:01 AM   #44
It's been a while the tf2 hasn't been playing in the dirt!
STHA videos
Old 07-20-2020, 08:47 PM   #45
What happened to the Ground Hawgs?
mulchman is offline   Reply With Quote
Old 07-21-2020, 09:20 AM   #46
I didn't like them too much, grip is not great. I much prefer the mud trashers. And I like the look on the tf2.
Old 07-23-2020, 11:50 AM   #47
New video with the tf2!
STHA videos
Old 07-24-2020, 09:41 PM   #48
Another awesome video.
Old 07-25-2020, 09:11 AM   #49
thank you!
Old 09-17-2020, 11:38 AM   #50
I did some tire test for the TF2 to get more ground clearance than with the mud trashers with 1.55’’ Stamped Steel Beadlock Wheels.
Started with pit bull 1.55 growler + 1.55’’ Stamped Steel Beadlock Wheels. It looks pretty cool but it rubbed a lot on the leaf springs, so to avoid this I had to minimize wheel steering angle which is not fun on the trails.
So I installed rc4wd trail buster 1.9 + 1.9 Stamped Steel Beadlocks, much narrower so turning radius is much improved, perfect combo with the Over/Under Drive Transfer Case to turn on a dime.
Both wheels are the same height so ground clearance is the same.
STHA videos
Old 09-18-2020, 05:52 AM   #51
STHA videos
Looks much better with the narrower tires
Dirt Runner is offline   Reply With Quote
Old 09-22-2020, 04:18 PM   #52
RC4WD Trail Finder 2 in the jungle!
We worked on a section of a trail that will be presented in our next video...
STHA videos
Old 09-22-2020, 07:12 PM   #53
Go Buckeyes!
B-MOW71's Avatar
WOW! Those pics! Great shots! Can't wait to see the video!
B-MOW71 is offline   Reply With Quote
Old 09-22-2020, 07:39 PM   #54
Thanks B-MOW71!!!
We've been working for a long time on this trail, still a LOT to do.
Our theme is King Kong, so we're working on bridges, gates, jungle look, etc...Stuff like that.
What's super cool is because we've been working and testing for so long, natural path has been created by the tires, pretty rad!
Stay tuned...
Old 09-23-2020, 06:45 AM   #55
Go Buckeyes!
B-MOW71's Avatar
Man that sounds like it is going to look awesome!
Love the look of trail paths made naturally be tiny tires!
Old 09-24-2020, 11:31 AM   #56
Most excellent photographs. So the rear suspension really flexes that well with leaves and a traction bar? Did you flip the tcase around for od, or is there a less aggressive aftermarket option, ratio wise that is?
meatmonkey is offline   Reply With Quote
Old 09-24-2020, 11:51 AM   #57
Thanks!
Photographing tiny trucks is definitely part of the fun for me
I added 90mm shocks with gelande II hoops in front, in the rear RC4WD Teraflex Revolver (kept the original shackles) for more articulation and it's awesome. Front has less flex, but that's the way I wanted, flips over a lot less.
No traction bar or any other mods other than grinding leaf springs a bit. Simple but efficient!
Driving with leaf springs is tons of fun, definitely not like links, but I really like this.
Old 10-18-2020, 09:12 AM   #58
foggy crawling with the TF2!
STHA videos
Old 10-18-2020, 05:49 PM   #59
I see you went back to the mud thrashers.
djr01974 is offline   Reply With Quote
Old 10-18-2020, 05:52 PM   #60
yes, but not for long...as I'm looking for a specific look, and the trail busters were too "aggressive" for this truck, so I tried something else...
Pictures very soon.
STHA Toyota HiLux - Similar Threads
Toyota Hilux VUCK and Toyota FJ40 AWESOME VID HOONIGAN Scale Videos! 0 06-01-2016 04:08 PM
HiluX-Trail Toyota Hilux ToyFarm 1.9 Scale Rigs 34 06-12-2009 11:11 PM
