03-14-2020, 05:09 AM | #1 |
Pebble Pounder Join Date: Dec 2011 Location: milford
| stock shocks holding oil
can the stock shocks on a tf2 hold oil? i run without springs in them and i dont like the bounce, is there a way to rebuild that will guarantee them holding oil? ive looked at other scale options but none look right in my opinion. i wanna keep this as my scale rig, not really a heavy crawler. any help would be appreciated. |
03-14-2020, 05:13 AM | #2 |
Pebble Pounder Join Date: Jan 2017 Location: Brookfield
| Re: stock shocks holding oil
I use 2000 cst diff fluid in the stock shocks with associated green slime on the orings. This seems to work well. Sent from my SM-N950U using Tapatalk |
03-14-2020, 05:30 AM | #3 |
i did try the diff fluid, but i wasnt a fan. i mean, if thats all that will work then i guess it is what it is, but wondering if there are some special o rings i should use
03-14-2020, 01:03 PM | #4 |
You can also try and put a 0.2mm or slighty thicker spacer between the oring and shaft guide. This will compress ther oring slightly and may cause a bit of resistance bit will eliminate or greatly reduce leaks. How thick of diff fluid did you use before? Sent from my SM-N950U using Tapatalk |
03-14-2020, 01:07 PM | #5 |
I had 5 k...just didnt feel right Sent from my SM-G965U using Tapatalk |
03-20-2020, 02:34 PM | #6 |
Newbie Join Date: Dec 2019 Location: Blue Mountains
These King Kong R/C scale shocks may be what you're after, oil filled and made for specifically scale appearances. Sent from my SM-A530F using Tapatalk |
04-29-2020, 02:16 PM | #7 | |
| Re: stock shocks holding oil Quote:
I've found 3000 CST diff fluid to be proper damping front and rear using RC4WD shocks and it leaks less. If the seals are leaking, replace them all and fill with 3000 cst, do NOT overfill or they'll leak. | |
04-30-2020, 08:19 AM | #8 |
Rock Crawler Join Date: Dec 2008 Location: Fortuna Calif.
I also filled mine with 8K shock fluid from my 5th scale car. They seem to work well and haven't leaked yet, just a slight wetness on the shaft.
05-02-2020, 07:50 PM | #9 |
Pebble Pounder Join Date: Dec 2011 Location: On, canada
I put some 30wt engine oil in mine. 1/4 leaks a decent amount(it'll prolly be empty in 2 months ish) the other 3 you cna see the shaft is wet but it's barely accumulating at the bottom of the shock. I feel it did help dampen the truck on high speed runs too, feels less bouncy and more controlled althouh for slower speed crawling it did slightly limit my travel, maybe 1/4" less now.
stock shocks holding oil - Similar Threads | ||||
Filling stock shocks with oil | NeoPyro | RC4WD Trail Finder 2 | 4 | 04-02-2017 09:25 PM |
For those that run stock shocks with no oil ... | TakeOffYouHoser | Axial SCX-10 | 60 | 01-18-2015 06:46 PM |
Stock Shocks, No Oil? | Freakshow185 | Axial Wraith | 3 | 05-17-2013 01:44 PM |
BEST Shock oil weight in stock shocks | autumnsummers1 | Axial AX-10 Scorpion | 10 | 02-09-2009 11:18 PM |
Who's running 1000wt oil in the stock shocks? | goldmember | Axial AX-10 Scorpion | 3 | 09-23-2008 08:13 PM |
