Thread: New Tf2 lwd upgrade
Old 08-08-2020, 03:48 PM   #21
Default Re: New Tf2 lwd upgrade
I can’t decide which ones I like better. 🤯Name:  348D426F-BA86-42D7-B33B-9DA0BBCC3010.jpeg
djr01974 is offline   Reply With Quote
Old 08-08-2020, 04:09 PM   #22
This is too funny. I did the same pic. I think yours looks better with the black wheels
I think mine looks better with the white. I think it may be the smaller tire.
Sent from my SM-N950U using Tapatalk
Dirt Runner is offline   Reply With Quote
Old 08-08-2020, 04:26 PM   #23
Go Buckeyes!
B-MOW71's Avatar
I like the black wheels better. Though it looks like the fronts may rub the body when the wheels are turned.
B-MOW71 is offline   Reply With Quote
Old 08-08-2020, 04:52 PM   #24
No rubbing at all. The tires are 3.85 general grabbers off my trailwalker. The wheels are ssd d slot 1.55
Old 08-08-2020, 05:04 PM   #25
Go Buckeyes!
B-MOW71's Avatar
Nice! It was hard to tell by looking at them on my tiny phone screen!
I do like them tires! They have been great on my Trailwalker!
Old 08-09-2020, 07:42 PM   #26
Here is a video from today’s first time out run. I’m thinking I may throw a set of 4.19 proline km3 class 1 1.9 tires on it. The stock tires are ok. I can’t tell any difference between the general AT and the mud thrashers.
https://youtu.be/3iXB7nkKhwo
Old 08-10-2020, 11:57 AM   #27
the truck looked really good. That is a great spot for it. the 4.19 will rub the lower front fender. Now I see why the marlin doesn't have the lower part.
Old 08-10-2020, 01:51 PM   #28
Yes I tried it when I got home it does rub with the 1.9. So I’ll run 1.55 I don’t feel like cutting up the body
Old 08-12-2020, 11:25 PM   #29
Kept the 1.55 wheels but in took the generals off and swapped with the growlers. Very slight rubbing. I think this looks pretty good.
Old 08-12-2020, 11:36 PM   #30
Looks great!
soze is offline   Reply With Quote
Old 08-13-2020, 06:02 AM   #31
Go Buckeyes!
B-MOW71's Avatar
Yeah, looks good!
Old 08-13-2020, 06:24 AM   #32
Thanks fellas I received my junfac metal shafts yesterday. Super nice pieces. I will be installing those soon. Still waiting on my dinky rc low pro transfer case mount / skid. 👍🏻 Mo money mo money 😂
Old 08-13-2020, 07:57 AM   #33
Ha ha I just received and installed my JunFac shafts yesterday. I wanted to use the longer set screw/pin that the stockers used, so I had to shorten the diff. and transfer case shafts just a little maybe 1mm or so. They are pretty nice first time to used this brand of shaft, nice scale look to them.
Big Bill is offline   Reply With Quote
Old 08-13-2020, 05:11 PM   #34
Very nice!👍🏻
Old 08-15-2020, 03:00 PM   #35
I have a tire and wheel problem so today I mounted up the class zero pro line crawlers to see how it looked on the TF2 looks pretty good for a 1.9 wheelName:  797CDC7D-696F-49BE-8B8B-F4562175E774.jpg
Old 08-15-2020, 03:31 PM   #36
I think it looks really good. To me the 4" and smaller tires look better on the tf2.
Old 08-15-2020, 06:15 PM   #37
Yes I agree. These will be staying on for a while or Until my ocd kicks in lmao. 😂
Old 08-15-2020, 06:51 PM   #38
Did you do the bowhouse rear shackle mounts? My lhs just ordered me a set. They terminate the shackle a bit further back ro prevent the leafs from locking up on compression.
Old 08-15-2020, 10:49 PM   #39
Dirt runner no I haven’t. I fully compressed the rear and my rear shackles hardly move. So for now I’m not going to be doing that.
Old 08-16-2020, 05:02 AM   #40
I wonder if it's the longer wheel base? After removing the internal springs from the shocks on mine it locks up on articulation.
New Tf2 lwd upgrade - Similar Threads
What is the best TF2 Suspension / Articulation upgrade? Digital RC4WD Trail Finder 2 0 01-11-2018 11:32 PM
Marlin TF2 mini build - LR2 Trans/T-case upgrade RattleKan RC4WD Trail Finder 2 8 11-24-2017 04:35 PM
TF2 single speed Pardonmyn00b OG 4runner upgrade 1BadJeepBruiser RC4WD Trail Finder 2 17 01-30-2013 11:12 AM
Looking for drive shaft upgrade on TF2 Lex07 RC4WD Trail Finder 2 15 10-27-2012 09:09 AM
