| | #1 |
| Rock Stacker Join Date: Aug 2005 Location: Eastern Washington
| Is RC4WD's Tracgear pinion pre-drilled? |
| Sponsored Links | |
| | #2 |
| Newbie Join Date: Apr 2006 Location: Genova, Italy
| Do you intend pinion for TLT-1? If so, I've a great doubt because it's pre-drilled 3mm hole so you need a screw-pin with pin portion diameter of 3mm... R2 5mm shaft is pre-drilled... which is the diameter of this hole? 2.5mm or 3mm? Thanks!!! :-P |
| | #3 |
| Gold Star Baby! ![]() Join Date: May 2007 Location: Taylors Falls just hanging with the MNRCRC crew.
| It's drilled not sure about size but it's steel and the ring is alumimum and very light compared to RCP's copper ring and pin. I have RCP in my comp rig and RC4WD in my scaler. |
| | #4 | |
Thanks a lot!! :-P | |
| Thread Tools | |
| Display Modes | |
