Thread: The Ultimate Scale Axle (Rear CAD Preview)
Old 02-29-2008, 02:08 AM   #1
Default The Ultimate Scale Axle (Rear CAD Preview)
This is still early stage of the design process, our goal is produce the ultimate scale looking and functional axle.
We will also make all the add on parts to go with this axle.
We hope to start shipping this axle, along with with a chassis late next month.
Another great news, we are working on a transfer case as well.
Old 02-29-2008, 02:26 AM   #2
My 2 cents of rant...
Dunno about Ultimate scale... does look functional though. Those integrated mounting points look very useful, although maybe work on those ones that hang down - they look like great snag points.
Im wondering what these offer that your other axles dont - it seems to me that you are going for a strong and easy to mountup axle, perhaps you should focus on giving it high versatility, ground clearance and simple shape.
personally, if you were going for ultimate scale I would suggest leaving the axle tubes completely bare, maybe with a couple of little lugs, and making the pumpkin as small as possible, with a realistic design, maybe through smaller & harder gears inside the pumpkin, and a very space efficient design.
You already have the danas, but I have yet to see a rear axle in 12mm hex bruiser style (correct me if Im wrong)
I would LOVE to see some scale steering knuckles, something like tamiya did with their bruiser axles - round as opposed to a standard C shape.
-If these are refined and optimised for effective link & shock mounting I would consider them good performance axles,
-If you made some with round knuckles and and a small pumkin; that I would consider the ultimate scale axle.
Keep up the good work
For what its worth.. I may try design a replica toyota axle, if it works out you will hear from me.
Fracture is offline   Reply With Quote
Old 02-29-2008, 08:00 AM   #3
that looks bad.. good job
tanner is offline   Reply With Quote
Old 02-29-2008, 11:26 AM   #4
looks good, but i wouldnt make use of the diff anyways because it would be fully locked 100% of the time
tpliquid is offline   Reply With Quote
Old 02-29-2008, 12:24 PM   #5
I <3 LS3
exesivefire's Avatar
Well... I love it!
exesivefire is offline   Reply With Quote
Old 02-29-2008, 12:33 PM   #6
I'm Dracula, Bitch.
JeremyH's Avatar
Nice work. You might want to move the shock mounts a bit higher on the tube. Even small diameter scale shocks might contact the housing. Unless, you plan to make scale shock relocators...
JeremyH is online now   Reply With Quote
Old 02-29-2008, 01:10 PM   #7
~The Scale Shop~
STANG KILLA SS's Avatar
swing the shock/link mounts (that are hanging down) up to where there 90* to the axle, sticking straight sideways, so they dont snag.
i think they look damn good. what are the vertical mounts on either side of teh pumpkin? upper link mounts? if so move those in 1/2" each.
STANG KILLA SS is offline   Reply With Quote
Old 02-29-2008, 01:47 PM   #8
why not do an offset pumpkin? that would be the "ultimate scale axle".
p!nK
mrpink is offline   Reply With Quote
Old 02-29-2008, 02:10 PM   #9
p!nK
How far offset do you want the pumpkin since this is a rear axle?
maxtrax is offline   Reply With Quote
Old 02-29-2008, 02:40 PM   #10
Old 02-29-2008, 04:13 PM   #11
and that axle is scale to a small few.
Old 02-29-2008, 06:11 PM   #12
Picky Fab'r/Acetal Junky
Offroader5's Avatar
What are the mounts right at the end of the axle tubes for?
Offroader5 is offline   Reply With Quote
Old 03-01-2008, 10:54 AM   #13
(Quote: Another great news, we are working on a transfer case as well.) Will this be shiftable in and out of 2wd/4wd? Thats what I've been waiting for!!
KAR 1316 is offline   Reply With Quote
Old 03-01-2008, 01:05 PM   #14
Im not sure if they are working on a shiftable one, but I gave them plans for a compact case with slight reduction that could bolt in where a r2 would.
Old 03-03-2008, 12:07 AM   #15
So does this mean I should hold off on ordering your new "Dino" axles coming next month?
Zurbz is offline   Reply With Quote
You may edit your posts
