Thread: Wheel and Shock Idea?
Old 02-29-2008, 06:36 AM   #1
Default Wheel and Shock Idea?
I'm not sure what everyone else thinks, but I know I would love to see these two items made. The first is a beadlock which many 1:1's run. Everyone from Full out comp rigs to Trail rigs run these things. So I can see these being used in many build threads.
The first is the Walker Evans beadlock. The second is a Coil Over shock. I know you already make shocks, but no one has came very close to a True Scale Coil Over. These would be a smaller Dia. shock then you already have, but would make some very nice scale additions to builds. So RC4wd what do you think?
Old 02-29-2008, 07:24 AM   #2
We already working on a shock like that, we still trying to figure out how to attached the piggy pack to the body.
In terms of that wheel, we will try to get a CAD done by next week
Old 02-29-2008, 07:59 AM   #3
that would be so cool if those were made
tanner is offline   Reply With Quote
Old 02-29-2008, 03:12 PM   #4
Axial Team Driver
Brandon's Avatar
Make the shock longer and smaller diameter please. Also the shock boots should be a option, most modern 1:1 shocks have them, but if they are getting used offroad nobody runs them. Especially if its a coilover!!
Brandon is offline   Reply With Quote
Old 02-29-2008, 04:01 PM   #5
Yep, Im all for a nice simple small diameter shock, just as you make it long enough. And it better not leak
Those wheels look pretty smooth aswell
Fracture is offline   Reply With Quote
Old 02-29-2008, 04:20 PM   #6
X2 on this
HITMAN is offline   Reply With Quote
Old 02-29-2008, 04:36 PM   #7
x3 at about 110-120mm fully extended
Thundermaxx is offline   Reply With Quote
Old 02-29-2008, 05:02 PM   #8
What about some RockMonster Beadlocks?
2JSC is offline   Reply With Quote
Old 02-29-2008, 05:19 PM   #9
Now that is an awesome design!
Old 02-29-2008, 05:23 PM   #10
This is shock is nothing like the one I posted. Yours is a Normal looking shock. Looks like your standard Rancho or Skyjacker shock. Looks nothing like Coil-Overs.
Old 02-29-2008, 05:43 PM   #11
yeah we need a full on coil-over....
wally187 is offline   Reply With Quote
Old 02-29-2008, 06:02 PM   #12
scale would be like a 10mm OD body or what ever the turndown tlt shocks are. It would be cool with the dual rate/spring and threaded.
Old 02-29-2008, 08:08 PM   #13
Yeah, and a scale shaft would be about the diameter of a sewing needle and bend the first time the shock tried to compress. Some of you scale guys need to be a little realistic with your expectations...
diesel72 is offline   Reply With Quote
Old 02-29-2008, 08:14 PM   #14
not sure im jumping out of bounds but 1 way to mount the resi you could do like the fuel lines on small deisel engines or fuekl injectors ill try to find a pic
mickrcarver is offline   Reply With Quote
Old 02-29-2008, 08:22 PM   #15
Picky Fab'r/Acetal Junky
Offroader5's Avatar
They already make the X10 & X11 shocks...so really the only difference would be the addition of a second coil and to shrink the whole shock down a bit in size.
Offroader5 is offline   Reply With Quote
Old 02-29-2008, 08:22 PM   #16
Maybe so, but it isnt impossible to make a 10mm OD shock that still works acceptably an uses standard diameter shafts.
Old 02-29-2008, 11:53 PM   #17
These would be fine if they weren't 1/5th Scaled.. Make these have a remote resv... and not the piggy back.. Then just scale them downsome. You can keep the Shaft larger and just scale down the Coilsprings Cups and shock Body. Does that make sense?
Old 03-01-2008, 02:58 AM   #18
run2jeepn, we will get a CAD for the wheel and Baja Shocks (smaller version) next week
Old 03-01-2008, 04:21 AM   #19
Sweet.. The wheel would be a great addition to your already great line of beadlocks.
The shock will be great as well. Just make sure to make it Scale..
Old 03-01-2008, 06:01 AM   #20
Yes it is, I already drew that in 1.9:
Katan is offline   Reply With Quote
You may edit your posts
