Thread: Mini T-Rex Axles
Old 03-25-2008, 12:23 PM   #1
Default Mini T-Rex Axles
We expect to ship within 1-2 weeks, axles width of 158 mm from outside hex to ouside hex.
Old 03-25-2008, 12:26 PM   #2
Nice..... Are these Narrower then TLT's?
run2jeepn is online now   Reply With Quote
Old 03-25-2008, 12:40 PM   #3
[HOONIGAN]
Wrecker's Avatar
Dang you guys are coming out with so much new stuff I can't even keep up with remembering it all! Those look sweet!
Wrecker is offline   Reply With Quote
Old 03-25-2008, 01:08 PM   #4
Scattman's Avatar
I just measured a set of TLT axles I have and they are 178mm hex to hex.
Scattman is offline   Reply With Quote
Old 03-25-2008, 01:49 PM   #5
Yes, they are much narrower than TLT's ... same width as my robbe type axles under my cherokees.
With HPI stock car rims you will get a nice scale overall width of app. 185 mm from outside tire to outside tire.
scaleoffroad is offline   Reply With Quote
Old 03-25-2008, 03:56 PM   #6
since you guys are doing a great job on scale axles, any chance on making a scale engine where a 540 motor and the plentery gear reduction would fit inside and then fit a scale transfer case that would mount to it. and also make the engine out of alluminum with tail pipes and maybe a fan for the radiator, and engine mounts just like the real 1-1 rigs?
r/cSith is offline   Reply With Quote
Old 03-25-2008, 04:14 PM   #7
another awsome product on the way
hairyguy4 is offline   Reply With Quote
Old 03-25-2008, 10:25 PM   #8
Width seems to be perfect for what I have coming up...
Old 03-26-2008, 12:53 PM   #9
Axial Team Driver
Brandon's Avatar
Awesome! Perfect width, now I need to find one of those jeep jk bodies
Brandon is offline   Reply With Quote
Old 03-26-2008, 09:16 PM   #10
I agree with that engine thing. maybe even have a little fan setup that takes air in through a faux air intake, cools the motor with that, then expells the used air through some holes in the block where exaust pipes would go. from stock have just like a little block that bolts to that area that has a single hole in the back (shouldn't be that hard to machine. one hole drilled on the end, 4 other holes drilled at set points onto the side that intersect the hole drilled down the center). I know these are a crawler axle, but with that width on the rear axle, imagine one of these sitting under, say, a HPI Camaro or '66 Mustang body, complete with leaf springs and wide offset HPI vintage rims and 31mm wide vintage tires. damn that would look cool. of course, it would also look cool under a Proline K5 with vintage stock car rims with faux beadlocks, being adorned with a set of the 1.9 Krazy Krawlers. towing abovementioned Camaro
Slyp Dawg is offline   Reply With Quote
Old 03-27-2008, 08:30 PM   #11
Meanwhile back in the real world......
Thorsteenster is offline   Reply With Quote
Old 03-27-2008, 10:24 PM   #12
06 Super National Champ
JasonInAugusta's Avatar
I have the perfect frame for a build.
I was going to narrow a set of TLT axles but hey...this will likely kick ass!
JasonInAugusta is offline   Reply With Quote
Old 03-27-2008, 10:33 PM   #13
Adilynsdad too!
braceysdad's Avatar
SHE's ALIVE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
braceysdad is online now   Reply With Quote
Old 03-27-2008, 10:59 PM   #14
Damn good idea there
Shaun (yota) is offline   Reply With Quote
Old 03-27-2008, 11:42 PM   #15
These are perfect for the JK body I recently snagged.
rc4wd - Will you be accepting pre-orders for these? (...are you already?)
I assume they're compatible with the existing t-rex 4-link mounts?
I can't wait!
tinsoldier is offline   Reply With Quote
Old 03-27-2008, 11:48 PM   #16
4 links mount should work, we dont take pre-order yet, we should have it ready for shipping in 2 weeks
Old 03-28-2008, 12:44 AM   #17
Web Wheeling
Etype R's Avatar
Perfect rig for these lil axles
Etype R is offline   Reply With Quote
Old 03-28-2008, 10:14 AM   #18
I'd like to see a narrow version of the Fracture Ultimate axles in the future too
utieh is offline   Reply With Quote
Old 04-03-2008, 06:28 AM   #19
Dirty Harry Crawler Team
jgroneng's Avatar
Hi,
Any updates on these axels? I definitly need some of them...
jgroneng is offline   Reply With Quote
Old 04-03-2008, 08:58 AM   #20
~The Scale Shop~
STANG KILLA SS's Avatar
finally a narrow scale axle, will these be available in plastic? im intrested.
You may edit your posts
