Thread: Blackwell X1 & X3 Axle Assembled
Old 01-21-2009, 01:29 AM   #1
Default Blackwell X1 & X3 Axle Assembled
We still have some work on this, hopefully we can ship a set to Brett for inspection next week.
We should be able to ship all pre-orders by early Feb.
Old 01-21-2009, 01:34 AM   #2
Speechless... I've got to get a pair...We need some holes for mounting links and shocks.
Old 01-21-2009, 03:03 AM   #3
X2
U DOWN is offline   Reply With Quote
Old 01-21-2009, 03:04 AM   #4
The most beautiful scale axles in the universe!
We need some measures: width, etc.
obsession4x4 is offline   Reply With Quote
Old 01-21-2009, 04:23 AM   #5
Default in desperate need of
this baby needs a REAL drivetrain
my never ending shoppin list just got rearranged!!
this is the most beautiful set of axles ive ever seen!!
gonna have to go 4WS now..
gadge is offline   Reply With Quote
Old 01-21-2009, 06:27 AM   #6
500swmag's Avatar
looks great RC4WD, cant wait to get a set to check out.
500swmag is online now   Reply With Quote
Old 01-21-2009, 07:18 AM   #7
RC4WD Team Mgr/W.Pa.C.
Rckcrwlr's Avatar
I second R2J...
Where will links or leafs and Shocks mount?
Rckcrwlr is online now   Reply With Quote
Old 01-21-2009, 09:38 AM   #8
Pure ART! Great job RC4wd!
Have you finalized a gear ratio for it yet?
What about leaf mounts as well?
cman_1500w is offline   Reply With Quote
Old 01-21-2009, 11:11 AM   #9
Nice work on both parts! Can't wait to see them in person!
Do you have an assembled weight on these yet?
HC Rc Guy is offline   Reply With Quote
Old 01-21-2009, 12:28 PM   #10
Those are brilliant! Can we get some detailed measurement shots so we can start building chassis?
Culetto is offline   Reply With Quote
Old 01-21-2009, 01:12 PM   #11
Shooter shackles,super soft springs,blackwells,and a jeep body! That's what ilm talking about. Are you folks gonna anodize these? Something similar to the bully's. Remeber to beef thos axle shaqfts and put those new hex's on them also.
keala is offline   Reply With Quote
Old 01-21-2009, 03:32 PM   #12
What he said.
I would love to stick a set of these under my Land Rover buggy.
Tupers is offline   Reply With Quote
Old 01-21-2009, 03:42 PM   #13
~The Scale Shop~
STANG KILLA SS's Avatar
agreed, need shock, link and leaf holes. even if its just holes to bolt on TLT stays. http://www.shop.rpphobby.com/product...&productId=584
and get rid of those mushroom head knuckle arms, 1 hole is fine. or line the holes along (parallel) the arm not perpidicular
Old 01-21-2009, 04:13 PM   #14
Practicing my launchs >:)
Robbob's Avatar
countersink or counter bore the screws on each side of the meatball?
Robbob is offline   Reply With Quote
Old 01-21-2009, 06:48 PM   #15
500swmag's Avatar
The reasoning behind the "mushroom arms" was to give the user the ability to chose which hole would bring the tie rod as tight to the backside of the wheel as possible (effected by wheels with different off set) and then grind the rest of the arm off at an angle if desired. One of those ideas that seemed like a good one at the time.
Old 01-21-2009, 10:03 PM   #16
I <3 LS3
exesivefire's Avatar
MOUNTING HOLES?
please dont ruin these with bulky brackets, please?
exesivefire is offline   Reply With Quote
Old 01-22-2009, 11:47 AM   #17
500swmag's Avatar
Originally Posted by exesivefire View Post
MOUNTING HOLES?
Alright all check this out, this is basically what my original intention was going to be for a link mount. It's kind of similiar to the real 1:1. I don't think it would create much of a hang up on the bottom of axle. Let me know what you guys think, I'll clean it up and send it off to RC4WD if you all think this will be ok.
-500
Old 01-22-2009, 04:40 PM   #18
-500
Perfect for the linked trucks, but I also hope that Hua can make a leaf spring mount (like the one for the T-Rex axle #X-394) to allow to fit those axles under their Bruiser chassis (or the Tamiya original one, of course)
P.S:
Those axles have an awesome looks so, please, don't make a lot of holes!!
Old 01-22-2009, 06:56 PM   #19
500swmag's Avatar
Originally Posted by obsession4x4 View Post
Perfect for the linked trucks, but I also hope that Hus can make a leaf spring mount (like the one for the T-Rex axle #X-394) to allow to fit those axles under their Bruiser chassis (or the Tamiya original one, of course)
P.S:
I figured something like this would get the job done for leafer builds.
All RC4WD needs to do is make some squared U bolts.
Old 01-22-2009, 08:09 PM   #20
The bracket for the four link will not allow for a double triangulated suspension. Need some mounting holes so we can fab a crossmember for the upper links. I also agree with RobBob countersink those two axle tube screws.
Mikey007 is offline   Reply With Quote
You may edit your posts
