Go Back   RCCrawler Forums > Vendors > RC4WD
Thread: Rckcrwlr's RC4WD Predator Tracks Unleashed
Old 12-12-2011, 06:25 PM   #1
Default Rckcrwlr's RC4WD Predator Tracks Unleashed
The Predator is Loose....
Rckcrwlr Presents RC4WD Predator Tracks Unleashed - YouTube
Rckcrwlr is offline
Old 12-12-2011, 06:28 PM   #2
Ah man that's sweet.
chopperray is offline
Old 12-12-2011, 07:18 PM   #3
Now to show you how the Predator attacks...
Started with my Cross Canyon JK with 1.9 Baja Claws...
First step is to open the cage and let the Predator out...it includes the tracks. Adapters are specific to axles. Currently there are adapters for the Axial AX10/SCX10 Axles. More will be coming.
The front adapter includes special high clearance knuckles, Tie rod, draglink and aluminum hexes.
As you can see there are tabs on the knuckles to keep the Tracks from spinning around.
Here's a comparison of the stock knuckle and the Predator Knuckle.
And here it is installed
You will need to use the tie rod being that the knuckles create a wider distance.
To mount the tracks, you remove the cap to expose the mounting...
Front mounted:
Rckcrwlr is offline
Old 12-12-2011, 07:22 PM   #4
Location: Taylors Falls just hanging with the MNRCRC crew.
Great video, those are to cool.
Stormin2u is offline
Old 12-12-2011, 07:31 PM   #5
Next is the rear axle. Same deal, the Predator Rear Adapters have the tabs.
here they are installed.
And here they are completely installed.
I would suggest that you add a little Blue Thread Lock on the Silver caps to keep them from loosening up.
Rckcrwlr is offline
Old 12-12-2011, 07:39 PM   #6
Originally Posted by Stormin2u View Post
Great video,
Thanks
Rckcrwlr is offline
Old 12-12-2011, 07:40 PM   #7
Lucky guy! Those things are sweeeet.
DRCrawlGood is offline
Old 12-12-2011, 07:43 PM   #8
Here are some action shots from the video session...
Rckcrwlr is offline
Old 12-12-2011, 07:55 PM   #9
Didn't have time to add brushless but by the time the snow falls, it will have CowBell to skim over the snowdrifts...
Rckcrwlr is offline
Old 12-12-2011, 08:11 PM   #10
Looks like they turned out great!
markturbo is offline
Old 12-12-2011, 08:42 PM   #11
RPP Hobby's Avatar
Santa has come early! He better not forget our shop .....LOL
RPP Hobby is offline
Old 12-12-2011, 09:03 PM   #12
im pretty sure these were made for my rig,
ill be getting a set as soon as i can......lots of winter left up here.
theyukonzoo is offline
Old 12-13-2011, 03:23 AM   #13
Sold out already :( when can we expect the second batch to be ready im dying to get my hands on a set ??
Randy_4life is offline
Old 12-13-2011, 03:51 AM   #14
Corey...are you sure you're not on the naughty list?
That is one cool rig.
Click on the waiting list, you will be emailed when they are available...
Rckcrwlr is offline
Old 12-13-2011, 11:22 AM   #15
Limited amount in stock right now...
RC4WD Predator Tracks (Pair)
Rckcrwlr is offline
Old 12-13-2011, 11:24 AM   #16
JUST PLACED MY ORDER....WOOOO HOOOOO!!!!
"thumb sup"
Lobonyc is offline
Old 12-13-2011, 11:37 AM   #17
can you post up some install close ups. I am curious what alows the tracks to pivot but not flip completely over?what keeps them from doing wheelies onto the rear end of the track each time you accelerate?
SO I am guessing these would not be comp legal? due to not being 1.9 or 2.2? would be fun addition to comps though
soutthpaw is offline
Old 12-13-2011, 11:45 AM   #18
Referring back to the installation of the first couple posts, there are tabs on the adapters that fit in notches on the tracks.
Rckcrwlr is offline
Old 12-13-2011, 11:53 AM   #19
How is the track tension adjusted? If the frontmost wheel pair is shimmed, does the track set come with different thickness shimms?
THuhtamaki is offline
Old 12-13-2011, 11:58 AM   #20
It is spring tension...
Rckcrwlr is offline
You may edit your posts
