08-08-2014, 07:57 PM | #201 |
Pebble Pounder Join Date: Mar 2012 Location: York
| Re: AX2 2 Speed Transmission for Axial Wraith & SCX10/Honcho
I have a question... How do you activate the servo to switch from hi/low? I know I would need a new radio but how do you get it all to work together? |
08-08-2014, 08:03 PM | #202 |
RCC Addict Join Date: Oct 2012 Location: Norcal
Servo, linkage and a switch on your radio. The trans comes with all the linkage. You can also use a mini servo. Last edited by Norton; 08-08-2014 at 08:08 PM. |
08-08-2014, 08:10 PM | #203 |
Thank you for the pics! Looks like an easy install. Does the spur stay exposed like that? What radio would you rrecommend? |
08-09-2014, 10:22 AM | #204 |
I have a Futaba 4PLS, love it. There are others though.
08-09-2014, 10:27 AM | #205 |
You can buy a cover here: AX2 Transmission Gear Guard |
08-18-2014, 08:03 AM | #206 |
RCC Addict Join Date: Jun 2013 Location: Port Saint Lucie, Florida
Ordered one which should be here Thursday. Question for you guys though. I'm geared perfectly for a Holmes Hobbies Crawlmaster Expert 13t. Will this motor work or should I pickup a higher turn motor? Don't want to burn up this motor. |
08-21-2014, 11:25 AM | #207 |
Trans came in today and will be installing a spare Solar D772 for the time being, but am trying to figure which micro servo i'll need. Would the HS-53 budget feather micro servo be enough? I've got a GT3C so i'll have endpoints dialed in. i can get a $4 servo but i rather spend a teeny bit more and get the hitec name and reputation Says 16oz at 4.8volts if left through the RX, or 20oz at 6volts if i run it through the BEC. Thanks in advance!! |
08-25-2014, 03:24 PM | #208 |
Newbie Join Date: Nov 2013 Location: dallas
did anyone hve trouble with the axial driveshafts i bought 104mm gpm steel shafts but the front is to long
08-25-2014, 07:49 PM | #209 |
Rock Crawler Join Date: Jan 2008 Location: Lehigh Valley, Pa
The issue is it's actually a wraith length trans, so using scx or ax shafts will likely result in one being too long if your running stock wheelbase. It's really as simple as cutting it down and your good to go. And as far as servo requirements I have run mine for probably. 2 yrs now with a furans s3001 plastic geared servo with no issue , so a weak servo will get the job done. |
10-07-2014, 12:16 PM | #210 |
Pebble Pounder Join Date: Oct 2014 Location: Santa Barbara
Question: I have a Novak Timbuk2 13.5t in my Jk and the lack of drag brakes is a deal killer. Hating that system since my favorite place to crawl has very steep terrain. Was thinking of swapping that system with my Wraith along with a AX2 trans. My thinking is that the lower gear will act as a drag brake if geared properly? And I would l like the cool factor and more speed on the Wraith. Just got into crawling, Dang, this is addicting$$$ Last edited by robbo; 10-07-2014 at 12:19 PM. |
10-07-2014, 12:25 PM | #211 |
Rock Crawler Join Date: Feb 2009 Location: Wrightstown
Your thinking would be fairly correct. In low gear it holds on a hill pretty good. Like you said if the gearing is right. |
10-07-2014, 01:04 PM | #212 | |
| Re: AX2 2 Speed Transmission for Axial Wraith & SCX10/Honcho Quote:
And i bought T-maxx shafts i cut down to the length needed fairly easy LOVE this trans with the 13.5T Redline on 3s | |
10-07-2014, 01:16 PM | #213 |
| Re: AX2 2 Speed Transmission for Axial Wraith & SCX10/Honcho |
10-07-2014, 04:34 PM | #214 |
I run a 35t brushed motor on a sidewinder. With the stock trans the drag brake didn't hold very well. But it holds now. I tend to run cheep motors too. |
10-07-2014, 09:09 PM | #215 |
Timbuk definitely has drag brake. Should be more then enough to hold this in either gear
10-08-2014, 12:09 AM | #216 |
It has hill brakes yes. Either on - do a front flip or off - uncontroled run away. Zero drag brakes to mantian a controlled steep decent. No in between.
10-08-2014, 09:19 AM | #217 |
If you decrease the amount if drag brake your using, it would in theory not lock up, and would roll with resistance. My buddy runs the same setup in a wraith with this trans and 13.5 motor. Really works great for everything, but he has a slightly humming roll on really steep hills
10-08-2014, 09:26 AM | #218 |
i've got my drag brake set semi-low. It will not hold on a hill without some throttle input as i didnt like doing an end0 every time i let off the throttle when not on a hill
10-08-2014, 09:48 AM | #219 |
I''ve played with different settings and its on or off. Contacted Novak and they where no help. I have read on this forum it's a common issue with Novak. My buddy has one and can't get drag brakes either. Aside from zero drag brakes it works good, I like the rock boost. I've already ruined a body from cartwheeling from it slamming the brakes, maybe just my unit but, I don't think I'm alone.
10-08-2014, 09:52 AM | #220 | |
AX2 2 Speed Transmission for Axial Wraith & SCX10/Honcho - Similar Threads | ||||
Axial Wraith & Honcho | Trailing in the Forest | burtonkidd | Videos! | 1 | 01-15-2012 03:47 PM |
2 speed transmission for honcho | Dfrog | Newbie General | 18 | 03-28-2011 07:52 AM |
