Thread: Ultra Compact Gear Reduction Unit
Old 09-19-2006, 07:24 AM   #1
Default Ultra Compact Gear Reduction Unit
Above is our the final prototype version. We will start production after we go through a few more testing.
The gear ratio is 4.3:1. This custom housing can be expanded all the way to 200:1 gear ratio if needed. Any other other gear ratio will be made base on request.
A picture with it mounted a 540 motor will be posted tomorrow.
Now we have gained a lots of experience in making micro size gears, we will start designing a 3 or 4 speed full metal tranmission. A prototype will be made end of next month.
The retail price will be 39.99 per unit. You will get the Ultra Compact GRU and a custom pinion gear for the motor.
Specs:
Overall diameter: 47mm
Height: 18mm
Output shaft diameter: 3mm (with a flat surface for mouting standard RC pinion gears)
Total gears: 4
Old 09-19-2006, 07:41 AM   #2
what are the gears made of?
Gula is offline   Reply With Quote
Old 09-19-2006, 09:02 AM   #3
hardened steel, housing is 6061 alum.
Old 09-19-2006, 09:04 AM   #4
TLTCrawlin's Avatar
Looks sweet!
TLTCrawlin is offline   Reply With Quote
Old 09-19-2006, 09:08 AM   #5
Originally Posted by rc4wd
Specs:
Height: 18mm
Total gears: 4
3mm shaft? not 3.17mm or stock 1/8" 540?
rockwerks is offline   Reply With Quote
Old 09-19-2006, 09:37 AM   #6
Those look pretty nice. Send me a set, and Ill Test them for you, and do a review.
beatnbruised is offline   Reply With Quote
Old 09-19-2006, 09:59 AM   #7
It is standard 3.17mm (1/8") output shaft.
Old 09-19-2006, 10:17 AM   #8
very good!
I will want one for a new super class project.
LMK if you need testers and or when they are available. nice work!
Old 09-19-2006, 11:35 AM   #9
Damnit I need one for my rig. Get those bad boys made.
Old 09-19-2006, 12:34 PM   #10
It's a setup!
jason's Avatar
Wow those look really cool!
jason is offline   Reply With Quote
Old 09-19-2006, 12:37 PM   #11
I can't wait to test this new product out for evey one.
What size pinion do I need. Also what pitch is it?
Cole82 is offline   Reply With Quote
Old 09-19-2006, 12:41 PM   #12
Read the thread oh mighty tester.............it comes with a custom pinion
Old 09-19-2006, 12:44 PM   #13
Sorry I just learned how to read last week.
Speak N Spell really is helping me out.
Old 09-19-2006, 03:29 PM   #14
AKA TOKEN
ColquittCustom405's Avatar
You guys are stepping up your game! Nice products man!
ColquittCustom405 is offline   Reply With Quote
Old 09-19-2006, 04:32 PM   #15
yeah this looks to badass, and the tranny u speak of for next month has my mouth waterin
roadblock is offline   Reply With Quote
Old 09-19-2006, 06:46 PM   #16
I'm a stupid C U N T!
slobin3d's Avatar
I would like to test this. I have a scale 2.2 build coming up here soon and i dont have room for a pede or similar tranny if this could be stacked to get a ratio so that it could run drirect drive it would be perfect
slobin3d is offline   Reply With Quote
Old 09-19-2006, 09:37 PM   #17
We already have a tester person selected a few days ago.
Making those gears will take a few weeks, we expect to ship 2nd week of next month.
Old 09-19-2006, 10:06 PM   #18
Ok, now if I'm not mistaken you can bolt up motor right to that, then that will bolt to where the motor would have bolted into the tranny? If so, I will pick one up as soon as they are available. My tlt may need some more grunt.
xjman is offline   Reply With Quote
Old 09-20-2006, 12:24 AM   #19
LIKES2CRAWL's Avatar
I need one of these BAD! Where do I sing up for one?
LIKES2CRAWL is offline   Reply With Quote
Old 09-20-2006, 04:22 AM   #20
Click the image to open in full size.Click the image to open in full size.
Here is the final specs
  • Gear reduction ratio: 2.9:1
  • Overall diameter: 46mm
  • Height: 18mm
  • Output shaft diameter: 3.17mm (with a flat surface for mouting standard RC pinion gears)
  • Total metal gears: 5
  • Total Parts: 10
We might release other gear ratio down the road, but the GRU unit will be taller. This is the most compact one that we can do for now.
We expect to ship mid October. The prototype will be shipped to the tester on Monday.
You may edit your posts
