Thread: Rokk One Chassis and Knuckles Preview
Old 09-22-2006, 02:47 PM   #1
Default Rokk One Chassis and Knuckles Preview
The Rokk One is our 2nd crawling chassis, it will comes with a stainless steel skid plate. And it is designed to work with our R1 transmission as well.
We expect to ship in 1-2 weeks.
We are half way done with our next generation clod buster knuckles. The finish, fit and quality will be much improved. Price might drop slightly too, because it uses less material now.
We expect to ship the new axle tube within 1-2 weeks as well, the target price will be around $59.99 for a pair.
Old 10-05-2006, 02:39 AM   #2
aloha mike,
i had recieved my knuckles for my txt but noticed that they where a little short i had to run washers on the outside to make up the difference so it won't slide in and out? i didn't have this problem on my other txt. thanx ka'aina
kaaina is offline   Reply With Quote
Old 10-05-2006, 11:38 AM   #3
Check the bag you got, it should came with some thick CNC machined washers, you will need to put that inside of the knuckle.
If you dont have it, just email us at rcrock(at)gmail.com, along with your order #.
Old 10-05-2006, 06:08 PM   #4
thanx for the reply yes mine did come with them but for some reason when i put them on the inside the knuckle can't turn so i grabbed some new washers and installed them on the outside which seems to work but just wanted to makesure that is how they are made. thanx ka'aina
Old 10-23-2006, 09:17 PM   #5
666
666's Avatar
So when do the new knuckles come out? I have broke a few of the steering arms on mine and i want to see what the new ones look like!
666 is offline   Reply With Quote
Old 10-23-2006, 10:29 PM   #6
This Friday. I should have some pictures very soon.
You may edit your posts
