| | #1 |
| I wanna be Dave Join Date: Sep 2004 Location: SF Bay Area
| Yes it's finally here: ![]() this is the biggest and most expensive wheel that we have ever made. We will take some better pictures next week. Last edited by rc4wd; 10-20-2006 at 12:52 AM. |
| Sponsored Links | |
| | #2 |
| | #3 |
| I wanna be Dave Join Date: Apr 2005 Location: Kennewick
| Nice! I bet those are pretty spendy!! Im guessing same as two sets of 2.2 beadlocks? |
| | #4 |
| Rock Crawler Join Date: May 2006 Location: United Kingdom,Scarborough
| buggy is $999.00 on tower FEATURES: Chassis: Narrow channel monocoque design 0.16" (4mm) thick, purple in color constructed of aircraft grade 6061 T6 aluminum Drive: Rear wheel gear drive Engine: 2 cycle 1.40 cu in (23cc) gasoline with pull starter, dual element foam air filter, primer, choke and kill switch Exhaust: Steel muffler routed to rear of vehicle with aluminum pipe Radio: HPI TF-10 3-channel FM 27MHz with steering and throttle trim steering dual rate, transmitter does not have charge jack, 3rd channel switch is for optional accessories, receiver has adjustable failsafe, 6V 2000mAh rechargeable receiver pack, AC charger water resistant housing on chassis with external charging jack and rubber cap for easy crystal changes Servos: Water resistant with high torque 25kg-cm steering servo Receiver Battery: 2000mAh, five sub C-cell 6V rechargeable pack Clutch: Automatic centrifugal type Ball Bearings: Full set included Shocks: Four Hyper Adjust Piston aluminum shocks with 5 externally adjustable dampening settings and dual rate springs for progressive dampening action on all surfaces Main Gear: 57 tooth Gearbox: Sealed Differentials: Viscous Torque Control can be tuned using different weight diff oils, hardened metal planetary gears Brakes: Ventilated dual disc Front Tires: HPI Dirt Buster Rib Pattern M compound 2.4" (60mm) wide 6.7" (170mm) outer diameter Rear Tires: HPI Dirt Buster Block Pattern S compound 3.1" (80mm) wide, 6.7" (170mm) outer diameter Wheels: 5-spoke, nylon 3-piece bead lock, bead is bolted to wheel to hold tire securely in place-no need for tire glue Body: Pre-painted buggy type with decals applied Rear Wing: Molded black plastic with decals applied Roll Cage: Baja style high impact nylon protects engine and body from crash damage Suspension: Fully adjustable, long travel double wishbone Caster: Adjustable, with shim 22 / 25.5* stock / 29 degrees caster/toe-in refers to the angle of the front suspension when viewed from the side of the car in relation to the chassis Camber: Adjustable, camber refers to the angle of the tops of the tires from vertical when viewed from front or behind vehicle Warranty: 2-year limited INCLUDES: HPI Baja 5B RTR buggy with 1.40 cu in (23cc) gasoline engine 27MHz FM radio, two water resistant servos, 3.4oz (100cc) 2-cycle oil, 2oz (60cc) shock oil, 1oz (30cc) diff oil, 1oz (30cc) air filter oil, tube of gear grease, 2000mAh receiver pack, wall charger, body with wing, extra air filter, wrenches, decal sheet and illustrated instruction manual REQUIRES: Unleaded Gasoline: 87-93 octane, mix gasoline and two cycle oil at 25:1 ratio Transmitter Batteries: 8 AA Screwdriver: Flat blade, 3/16" (4-5mm) wide SPECS: Vehicle- Length: 32.2" (817mm) Front Width: 18.1" (460mm) Rear Width: 18.9" (480mm) Height: 10" (255mm) with 1G, 11" (280mm) with 0G Ride Height: 3" (76mm) Suspension Travel: Front 3.7" (95mm), Rear 3.9" (100mm) Weight: 21.3 lbs (9.6kg)(approx.) Wheelbase: 22.4" (570mm) wheels on-center front-to-rear Front Tread: 15.0" (382mm) Rear Tread: 15.8" (402mm) wheels on-center side-to-side _ Front Track: 17.4" (442mm) Rear Track: 18.1" (460mm) outer edges of wheels Gear Ratio: 8.382:1 Tires- Front: 2.4" (60mm) x 6.7" (170mm) Rear: 3.1" (80mm) x 6.7" (170mm) Body- Length: 22.9" (581mm) Width: 8.8" (224mm) at rear wheels (widest point) 3.25" (82mm) ahead of front wheels (thinnest point) Height: 4.75" (121mm) at highest point Last edited by Moondust1950; 11-02-2006 at 02:28 AM. |
| | #5 |
| Quarry Creeper Join Date: May 2006 Location: Oregon
| Those make me want a Baja that much more! Nice rims! |
| | #6 |
| Thread Tools | |
| Display Modes | |
