Thread: Portal axle for TLT-1?
Old 10-29-2006, 10:16 PM   #1
Default Portal axle for TLT-1?
We are working on this right now, but how much additional clearance do you guys want?
Old 10-29-2006, 10:20 PM   #2
10mm would be awesome.
FrankyRizzo is offline   Reply With Quote
Old 10-29-2006, 10:22 PM   #3
OOOO...I would down for a set with the scale axles. Any update on the axles yet?
rc4x4nut is offline   Reply With Quote
Old 10-29-2006, 10:32 PM   #4
FrankyRizzo, is 10mm enough. We were thinking to do about 20mm?
rc4x4nut, the scale 1/10 scale axle is already in production, should be available mid or November. We are still working on the 1/16 scale axle design, no real solid ETA yet.
Old 10-29-2006, 10:37 PM   #5
20mm is almost an inch. I am afraid that would put weight higher up. I personally have not had a real big issue with actual axle clearance. I think a way to get a tummy tuck and break over on a TLT is more key for me.
Old 10-29-2006, 10:39 PM   #6
You are talking about the TLT axles right?
Old 10-29-2006, 10:42 PM   #7
The first portal axle is for TLT-1
Old 10-29-2006, 10:48 PM   #8
How much additional clearance can you add, and still have the portal fit inside the most popular 2.2 rims?
Cubman is offline   Reply With Quote
Old 10-29-2006, 10:51 PM   #9
It will be outside the wheel...The truck will be wider.
Old 10-29-2006, 10:53 PM   #10
How much wider? Can the track stay within 10 1/2 inches?
Old 10-29-2006, 10:55 PM   #11
I will have the CAD image within the next 48-62 hours, we can take a look then.
Old 10-29-2006, 11:12 PM   #12
It sounds all good. If the Portal can't fit inside the wheel. Whats the point. Then the portal is sticking out like a sore thumb and hitting rocks.
Old 10-31-2006, 05:58 AM   #13
what if you use the wheels off of the new rustler/pede would that give you a little bit more clearance right?
Smurf is offline   Reply With Quote
Old 10-31-2006, 08:25 AM   #14
But they are not 2.2 legal.
Old 11-05-2006, 01:11 AM   #15
dude im down for a set!
dieselfuel is online now   Reply With Quote
You may edit your posts
